Threads: 6
Dear readers,
I am looking for the api of Goodwe inverters (Semsportal)
on Github I found the below but I don't know how to integrate this into the W4K.
Can someone help me with this?
thanks in advance
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
User details here #####
Givenergy Portal API Key Goes Below between " "
email =
"username@email.com"
password =
"password_here"
Powerstation_Id =
"Portal_ID_here"
end user input #############
Login to SEMS API ##
headers =
New-Object "System.Collections.Generic.Dictionary[[String],[String]]"
headers.Add (
"sec-ch-ua" ,
"`" Not A ;
Brand `
";v=`" 99 `
", `" Chromium `
";v=`" 99 `
", `" Microsoft Edge `
";v=`" 99 `
headers.Add (
"Accept" ,
"application/json, text/javascript, */*; q=0.01" )
headers.Add (
"Content-Type" ,
"application/x-www-form-urlencoded; charset=UTF-8" )
headers.Add (
"X-Requested-With" ,
"XMLHttpRequest" )
headers.Add (
"sec-ch-ua-mobile" ,
"?0" )
headers.Add (
"User-Agent" ,
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.51 Safari/537.36 Edg/99.0.1150.39" )
headers.Add (
"sec-ch-ua-platform" ,
"`" Windows `
headers.Add (
"Origin" ,
"https://eu.semsportal.com" )
headers.Add (
"Sec-Fetch-Site" ,
"same-origin" )
headers.Add (
"Sec-Fetch-Mode" ,
"cors" )
headers.Add (
"Sec-Fetch-Dest" ,
"empty" )
headers.Add (
"Referer" ,
"https://eu.semsportal.com/home/login" )
headers.Add (
"Accept-Language" ,
"en-GB,en;q=0.9,en-US;q=0.8" )
body =
"account=$email&pwd=$password&code="
response =
Invoke-WebRequest 'https://eu.semsportal.com/Home/Login' -
Method 'POST' -
Headers $
headers -
Body $
body -
SessionVariable session
response.Content |
Out-File -
FilePath.\Login.txt
session |
Out-File -
FilePath.\Session.txt
Write-Output "Login Response Saved to: Login.txt"
headers2 =
headers2.Add (
"sec-ch-ua" ,
"`" Not A ;
Brand `
";v=`" 99 `
", `" Chromium `
";v=`" 99 `
";v=`" 99 `
headers2.Add (
"Accept" ,
headers2.Add (
"Content-Type" ,
headers2.Add (
"XMLHttpRequest" )
headers2.Add (
"?0" )
headers2.Add (
"User-Agent" ,
headers2.Add (
"`" Windows `
headers2.Add (
"Origin" ,
headers2.Add (
"Sec-Fetch-Site" ,
"same-origin" )
headers2.Add (
"Sec-Fetch-Mode" ,
"cors" )
headers2.Add (
"Sec-Fetch-Dest" ,
"empty" )
headers2.Add (
"Referer" ,
"https://eu.semsportal.com/PowerStation/PowerStatusSnMin/$Powerstation_Id" )
headers2.Add (
"Accept-Language" ,
body2 =
"str=%7B%22api%22%3A%22v1%2FPowerStation%2FGetMonitorDetailByPowerstationId%22%2C%22param%22%3A%7B%22powerStationId%22%3A%22$Powerstation_Id%22%7D%7D"
response2 =
Invoke-RestMethod 'https://eu.semsportal.com/GopsApi/Post?s=v1/PowerStation/GetMonitorDetailByPowerstationId' -
Method 'POST' -
Headers $
headers2 -
Body $
body2 -
WebSession $
session
response2.data.inverter [
0 ].
invert_full |
ConvertTo-Json -
Depth 10 |
Out-File -
FilePath .\
Data\GoodweData.txt -
Encoding ASCII
Write-Output "Data Saved to: GoodweData.txt"
Write-Output "All done - Closing Powershell in 5...."
start-sleep -
s 5
Exit
Threads: 43
Use this as a starting point:
require (
'socket.http' )
require (
'ltn12' )
require (
'json' )
email =
password =
"password_here"
powerstation_id =
"Portal_ID_here"
function encodepost (
t )
local res = {}
local esc =
require (
'socket.url' ).
escape
for k ,
v in pairs (
t )
do
res [ #
res +
1 ] =
esc (
k ) ..
esc (
v )
return table.concat (
res ,
body =
encodepost ({
account =
email ,
pwd =
password ,
code =
headers = {
"sec-ch-ua" ] =
"\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"99\", \"Microsoft Edge\";v=\"99\"" ,
"Accept" ] =
"application/json, text/javascript, */*; q=0.01" ,
"Content-Type" ] =
"application/x-www-form-urlencoded; charset=UTF-8" ,
"X-Requested-With" ] =
"XMLHttpRequest" ,
"sec-ch-ua-mobile" ] =
"?0" ,
"User-Agent" ] =
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.51 Safari/537.36 Edg/99.0.1150.39" ,
"sec-ch-ua-platform" ] =
"\"Windows\"" ,
"Origin" ] =
"https://eu.semsportal.com" ,
"Sec-Fetch-Site" ] =
"same-origin" ,
"Sec-Fetch-Mode" ] =
"cors" ,
"Sec-Fetch-Dest" ] =
"empty" ,
"Referer" ] =
"https://eu.semsportal.com/home/login" ,
"Accept-Language" ] =
"en-GB,en;q=0.9,en-US;q=0.8" ,
"Content-Length" ] = #
body ,
response = {}
res ,
code ,
hdrs ,
stat =
socket.http.request ({
url =
"https://eu.semsportal.com/Home/Login" ,
method =
"POST" ;
headers =
headers ,
source =
ltn12.source.string (
body ),
sink =
ltn12.sink.table (
response ),
log (
res ,
code ,
hdrs ,
stat ,
response )
Post what you get in Logs tab.
Threads: 6
arg :
number :
arg :
number :
200
arg :
3
table :
"server" ]
string :
nginx
"content-type" ]
string :
application /
json ;
charset =
utf-8
"connection" ]
string :
close
"content-length" ]
string :
109
"cache-control" ]
string :
private
"x-aspnetmvc-version" ]
string :
5.2
"set-cookie" ]
string :
ASP.NET_SessionId =
pltv2ppqqnlhzlhalnlmh3gu ;
path =/;
HttpOnly ;
SameSite =
Lax ,
ASP.NET_SessionId =
path =/;
HttpOnly ;
SameSite =
Lax ,
language =
en ;
path =/
"x-powered-by" ]
string :
ASP.NET
"x-aspnet-version" ]
string :
4.0.30319
"date" ]
string :
Fri ,
07 Oct 2022 06 :
57 :
38 GMT
arg :
4
string :
HTTP /
1.1 200 OK
arg :
5
table :
1 ]
string : {
"code" :
0 ,
"msg" :
"data" :{
"redirect" :
"/PowerStation/PowerStatusSnMin/--Inverter id--" }}
Here the log tab,
Thanks admin
how do i get the power logs from the inverter?
Threads: 43
Try this:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
require (
'socket.http' )
require (
'ltn12' )
require (
'json' )
email =
password =
"password_here"
powerstation_id =
"Portal_ID_here"
t )
local res = {}
local esc =
require (
'socket.url' ).
escape
for k ,
v in pairs (
t )
do
res [ #
res +
1 ] =
esc (
k ) ..
esc (
v )
res ,
body =
encodepost ({
account =
email ,
pwd =
password ,
code =
headers = {
"sec-ch-ua" ] =
"Accept" ] =
"Content-Type" ] =
"XMLHttpRequest" ,
"?0" ,
"User-Agent" ] =
"\"Windows\"" ,
"Origin" ] =
"same-origin" ,
"cors" ,
"empty" ,
"Referer" ] =
body ,
response = {}
res ,
code ,
hdrs ,
stat =
url =
method =
"POST" ,
headers =
headers ,
source =
body ),
sink =
ltn12.sink.table (
response ),
cookie =
hdrs [
'set-cookie' ]
if cookie then
headers [
"Cookie" ] =
cookie :
split (
1 ]
headers [
"Referer" ] =
"https://eu.semsportal.com/PowerStation/PowerStatusSnMin/" ..
powerstation_id
log (
res ,
code ,
hdrs ,
stat ,
response )
body =
encodepost ({
str =
json.encode ({
api =
"v1/PowerStation/GetMonitorDetailByPowerstationId" ,
param = {
powerStationId =
powerstation_id
response = {}
res ,
code ,
hdrs ,
stat =
url =
"https://eu.semsportal.com/GopsApi/Post?s=v1/PowerStation/GetMonitorDetailByPowerstationId" ,
method =
"POST" ,
headers =
headers ,
source =
body ),
sink =
ltn12.sink.table (
response ),
log (
res ,
code ,
hdrs ,
stat ,
response )
Threads: 6
arg :
number :
arg :
number :
200
arg :
3
table :
"server" ]
string :
nginx
"content-type" ]
string :
application /
json ;
charset =
utf-8
"connection" ]
string :
close
"content-length" ]
string :
55
"cache-control" ]
string :
private
string :
5.2
"date" ]
string :
Fri ,
07 Oct 2022 10 :
32 :
21 GMT
"x-powered-by" ]
string :
ASP.NET
string :
4.0.30319
arg :
4
string :
HTTP /
1.1 200 OK
arg :
5
table :
1 ]
string : {
"code" :-
100 ,
"msg" :
"Network failure, please try again" }
Threads: 43
Can you send your credentials via PM?
Threads: 43
Try this:
require (
'socket.http' )
require (
'ltn12' )
require (
'json' )
email =
password =
powerstation_id =
t )
local res = {}
local esc =
require (
'socket.url' ).
escape
for k ,
v in pairs (
t )
do
res [ #
res +
1 ] =
esc (
k ) ..
esc (
v )
res ,
body =
json.encode ({
account =
email ,
pwd =
password ,
is_local =
True ,
agreement_agreement =
token =
json.encode ({
uid =
timestamp =
0 ,
token =
client =
"web" ,
version =
language =
"en-GB" ,
headers = {
"Content-Type" ] =
"application/json; charset=utf-8" ,
"Accept" ] =
"Content-Type: application/json; charset=UTF-8" ,
body ,
"Accept" ] =
"application/json" ,
"token" ] =
token ,
response = {}
res ,
code ,
hdrs ,
stat =
url =
"https://eu.semsportal.com/api/v2/Common/CrossLogin" ,
method =
"POST" ,
headers =
headers ,
source =
body ),
sink =
ltn12.sink.table (
response ),
if res and code ==
200 then
response =
json.decode (
table.concat (
response ))
headers.token =
json.encode (
response.data )
url =
response.api ..
"/v2/PowerStation/GetMonitorDetailByPowerstationId"
response = {}
body =
json.encode ({
powerStationId =
powerstation_id })
headers [
body
res ,
code ,
hdrs ,
stat =
url =
url ,
method =
"POST" ,
headers =
headers ,
source =
body ),
sink =
ltn12.sink.table (
response ),
response =
json.decode (
table.concat (
response ))
invert_full =
response.data.inverter [
1 ].
invert_full
log (
invert_full )
Threads: 6
Admin this works perfectly thanks
I will continue with this.
Threads: 24
(10.10.2022, 12:10) Danny Wrote: Admin this works perfectly thanks
@Danny: What is your experience with the script? Is it working? Have you made further modifications?
Many thanks!
Threads: 24
04.06.2023, 11:03
(This post was last modified: 04.06.2023, 11:05 by pioneersteffen .)
Hi @all,
Many thanks for the script it works perfectly, I getting a response as following:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292
SEMS 04.06.2023 12 :
49 :
42
table :
"backUpVload_S" ]
number :
"istr10" ]
number :
670
"battary_work_mode" ]
number :
"etotal" ]
number :
61.6
"pbackup" ]
number :
"istr3" ]
number :
"istr15" ]
number : -
810.4
"bms_alarm" ]
number :
"pre_hour_lasttotal" ]
userdata :
NULL
"bms_discharge_i_max" ]
userdata :
NULL
"sn" ]
string :
56000DTS229R0076
"isbuettey" ]
bool :
false
"backUpPload_T" ]
number :
"istr14" ]
number :
185.2
"total_buy" ]
number :
"ram" ]
number :
53
"dataloggersn" ]
string :
"genset_etotal" ]
userdata :
NULL
"istr16" ]
number :
560.4
"genset_mode" ]
userdata :
NULL
"iac2" ]
number :
5
"battery8sn" ]
userdata :
NULL
"reactive_power" ]
number :
"name" ]
string :
SDT G2
"ezPro_connect_status" ]
userdata :
NULL
"backUpIload_S" ]
number :
"mtActivepowerR" ]
number :
"fac3" ]
number :
50.01
"meter_type" ]
userdata :
NULL
"istr13" ]
number :
220
"pac" ]
number :
3457
"vpv2" ]
number :
360.2
"mtActivepowerT" ]
number :
"cts" ]
userdata :
NULL
"tempperature" ]
number :
56.3
"eDischargeDay" ]
number :
"ibattery1" ]
number :
"istr6" ]
number :
0.1
"istr8" ]
number :
118
"istr1" ]
number :
5.1
"yesterdaysellertotal" ]
number :
"more_batterys" ]
userdata :
NULL
"outputpower" ]
number :
3457
"mtActivepowerS" ]
number :
"eTotalBuy" ]
userdata :
NULL
"master" ]
userdata :
NULL
"powerstation_id" ]
string :
fe648d7b-b84b-4427-bb5f-f4b4a5c4c17b
"istr4" ]
number :
"istr7" ]
number :
64.7
"ipv2" ]
number :
5
"eP_connect_status_recover" ]
userdata :
NULL
"isbuetteybpu" ]
bool :
false
"buy" ]
number :
"last_time" ]
number :
1685875672648
"ipv4" ]
number :
"genset_yeasterdayTotal" ]
userdata :
NULL
"iload" ]
number :
"isESUOREMU" ]
bool :
false
"backUpPload_S" ]
number :
"change_type" ]
number :
"backUpVload_T" ]
number :
"meterConnectStatus" ]
userdata :
NULL
"current_hour_pv" ]
number :
"battery3sn" ]
userdata :
NULL
"pre_hour_time" ]
userdata :
NULL
"thismonthetotle" ]
number :
43.1
"hasmeter" ]
bool :
false
"bms_warning" ]
number :
"battery4sn" ]
userdata :
NULL
"yesterdayct2sellertotal" ]
userdata :
NULL
"eBatteryCharge" ]
userdata :
NULL
"pmeter" ]
number :
"hour_total" ]
number :
26
"istr9" ]
number :
669.3
"iac3" ]
number :
5
"battery5sn" ]
userdata :
NULL
"soh" ]
number :
"isbuetteybps" ]
bool :
false
"all_eday" ]
number :
18.5
"iac1" ]
number :
5.1
"turnon_time" ]
number :
1685712233090
"battery1sn" ]
userdata :
NULL
"equipment_name" ]
userdata :
NULL
"battery6sn" ]
userdata :
NULL
"vac1" ]
number :
226.3
"vac3" ]
number :
224.2
"genset_power" ]
userdata :
NULL
"status" ]
number :
"itotal" ]
number :
7.392
"battery_count" ]
userdata :
NULL
"total_pbattery" ]
number :
"workmode" ]
number :
"inverter_type" ]
number :
"parallel_code" ]
userdata :
NULL
"vpv3" ]
number :
"vpv1" ]
number :
346
"eBatteryDischarge" ]
userdata :
NULL
"deratingMode" ]
userdata :
NULL
"safetyConutry" ]
number :
79
"errors" ]
table :
"extend_properties" ]
userdata :
NULL
"istr5" ]
number :
0.1
"genset_eday" ]
number :
"check_code" ]
string :
045109
"isoLimit" ]
number :
"eday" ]
number :
18.5
"eDayBuy" ]
number :
"battery7sn" ]
userdata :
NULL
"yesterdaybuytotal" ]
number :
"model_type" ]
string :
GW6K-DT
"vac2" ]
number :
225.1
"fault_messge" ]
number :
"soc" ]
number :
44
"genset_start_mode" ]
userdata :
NULL
"yesterdayetotalload" ]
number :
"yesterdayetotal" ]
userdata :
NULL
"yesterdaylastime" ]
number :
"vbattery1" ]
number :
"bms_charge_i_max" ]
number :
3
"total_sell" ]
number :
"pv_power" ]
number :
"iday" ]
number :
2.22
"lastmonthetotle" ]
number :
0.4
"eChargeDay" ]
number :
"backUpIload_T" ]
number :
"vpv4" ]
number :
"battStrings" ]
userdata :
NULL
"istr12" ]
number :
220
"seller" ]
number :
"firmwareversion" ]
number :
1515
"istr11" ]
number :
"istr2" ]
number :
5
"change_time" ]
number :
"fac1" ]
number :
50.01
"capacity" ]
number :
6
"bmssoftwareversion" ]
userdata :
NULL
"ct_solution_type" ]
number :
"leakage_current" ]
userdata :
NULL
"pf" ]
number :
"ipv3" ]
number :
"ipv1" ]
number :
5.1
"fac2" ]
number :
50.01
"vload" ]
number :
"battery2sn" ]
userdata :
NULL
"eP_connect_status_happen" ]
userdata :
NULL
How can I pick a variable out of the table?
For example I want to pick out “pac” and write this value to a group address. How would this work?
Many thanks!
Best Regards
Steffen
Threads: 43
Use this:
grp.checkupdate (
'1/1/1' ,
invert_full.pac )
Threads: 24
(05.06.2023, 06:13) admin Wrote: Use this:
grp.checkupdate (
'1/1/1' ,
invert_full.pac )
Many thanks admin! Works perfectly! :-)
Threads: 12
I have a system with 2 inverters and one batterij, connected to one inverter.
I have copied the code above, but I have the impression that only the data from one inverter is displayed. How can I display the data of the other inverter?
Threads: 43
Try this for multiple inverters. The order of the returned data might not be constant. So you might have to check the serial number (sn field) invert_full_1 and invert_full_2 tables to distinguish to which inverter the data belongs to.
invert_full_1 =
1 ].
invert_full
log (
invert_full_1 )
invert_full_2 =
2 ].
invert_full
log (
invert_full_2 )
Threads: 12
(14.06.2023, 07:02) admin Wrote: Try this for multiple inverters. The order of the returned data might not be constant. So you might have to check the serial number (sn field) invert_full_1 and invert_full_2 tables to distinguish to which inverter the data belongs to.
invert_full_1 =
1 ].
invert_full
log (
invert_full_1 )
invert_full_2 =
2 ].
invert_full
log (
invert_full_2 )
I works perfect! Thank you very much.
But, now, I have the error: attempt to concatenate field 'api' (a nil value) stack traceback. The line with causes the error is:
url =
response.api ..
A couple of days ago, I didn't have this error. I tried several thing, but I can't find what is causing the error. Can you help?
Threads: 43
Log the response from the CrossLogin request:
res ,
code ,
hdrs ,
stat =
url =
method =
"POST" ,
headers =
headers ,
source =
body ),
sink =
ltn12.sink.table (
response ),
if res and code ==
200 then
response =
json.decode (
table.concat (
response ))
log (
response )
headers.token =
json.encode (
response.data )
Threads: 12
I get:
table :
"msg" ]
string :
error
"data" ]
table :
"timestamp" ]
number :
1687202887500
"uid" ]
string :
11c54dcf -
50cb -
48a5 -
aec2-91b915557029
"token" ]
string :
bcbccfa1fa74b141c8d20cad4e7a1d7d
"version" ]
string :
"client" ]
string :
web
"language" ]
string :
en-GB
"hasError" ]
bool :
false
"api" ]
string :
https ://
eu.semsportal.com /
api /
"components" ]
table :
"langVer" ]
number :
183
"api" ]
string :
http ://
eu.semsportal.com :
82 /
api /
Auth /
GetTokenV2
"msgSocketAdr" ]
string :
https ://
eu-xxzx.semsportal.com
"timeSpan" ]
number :
"para" ]
userdata :
NULL
"code" ]
number :
Threads: 43
The response looks fine. You can modify this part to log only when api field is missing from the response, then check what the log says:
if res and code ==
200 then
response =
json.decode (
table.concat (
response ))
headers.token =
json.encode (
response.data )
if not response.api then
log (
'invalid response' ,
response )
url =
response.api ..
response = {}
body =
json.encode ({
powerStationId =
powerstation_id })
headers [
body
res ,
code ,
hdrs ,
stat =
url =
url ,
method =
"POST" ,
headers =
headers ,
source =
body ),
sink =
ltn12.sink.table (
response ),
response =
json.decode (
table.concat (
response ))
Threads: 12
Thank you very much for your help.
I still have one question. In the Goodwe app, I can see how many we inject. I want to load in into the LM, so I can ask to the heat pump to make more hot water so it fulfills also the function of a battery. When I send use the following script:
url =
response.api ..
response =
json.decode (
table.concat (
response ))
log (
response )
The log ends with ..., so I have the impression that not everything is saved in the log and that I can't see everything.
Is there a possibility to saved everything, so that I can see alle the information that the LM is getting back.
Threads: 43
For testing purposes you can write the results into a file before decoding it:
response =
table.concat (
response )
io.writefile (
'/www/log.json' ,
response )
response =
json.decode (
response )
Then open the log in your browser:
http://LM_IP/log.json
You can use
https://codebeautify.org/jsonviewer to view the JSON contents in a more readable form.
