RE: MODBUS TCP SLAVE AND RECEIVE
Hello.
I have a question. I need to send and receive data through the LM in Modbus slave mode.
When I write the data to my register, the master can read it, but when the master try to send me a data,  doesn't work.  I can't read the register. I think that the master can not write me in my register, I always see nill when i try to read. can you help
if not mb then   require('luamodbus')       mb = luamodbus.tcp()   res, err = mb:open('0.0.0.0', 502)   res, err = mb:setslave(2)   log("Modbus slave IN : 502/2")     function setintmo(grpaddr, regaddr)         local value = grp.getvalue(grpaddr) or 0     res, err = mb:setregisters(regaddr, value)       end ------- setint(grpaddr, regaddr)   function setintresgis (direc, regist)                  local valuer = mb:readregisters(regist)     log (valuer)     if valuer ~= nill then        grp.write(direc, valuer)       end             end --- setintresgis (direc, regist)         function updateregisters()     setintmo('32/1/2', 2)   end --- updateregisters()     function updateinputregisters()      setintresgis('32/1/4',10)     end           mb:setmapping(100, 100, 100, 100)   updateregisters()   updateinputregisters()   end --- mb mb:handleslave() curr = os.time() if curr ~= prev then updateregisters() updateinputregisters() log ('A')   prev = curr end
In original description of this script it says it is read-only. Why don't you just use universal slave script?
https://openrb.com/lm-as-modbus-tcp-slave/
I understand that it is for read only. But I need to write too, can you help me with a script for writing?
Use this
https://forum.logicmachine.net/showthread.php?tid=4288
