Password field
Hey everybody,
I'm looking to display a login widget on the visualisation, containing a username box and a password box
my question is, how to put a password field in the visualisation ? Meaning not showing the password as it is being typen in, like with * or # for example
Thanks in advance
See this: https://forum.logicmachine.net/showthread.php?tid=2339
(13.10.2022, 13:02)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=2339
Thanks a lot  Big Grin
I tried to implement the Javascript Code at the end of the thread
12345678910111213
.password .value {   color: transparent;   position: relative; } .password .value:after {   color: #333;   position: absolute;   left: 0;   right: 0;   top: 3px;   content: "*****"; }
and used 'password' as an additional class to the objects but didn't work
do you know the reason why ?
This is CSS not JS.
(13.10.2022, 14:13)admin Wrote: This is CSS not JS.
Thought so.
How can I use it then ?
Vis. graphics > Edit Custom CSS
(13.10.2022, 14:17)admin Wrote: Vis. graphics > Edit Custom CSS
hmm it doesn't work
while typing it is working but not masking the value
maybe I'm doing something wrong
Do you have an Idea ?
Try this CSS
1234567891011121314
.password.item-value {   color: transparent ;   position: relative ; } .password.item-value:after {   color: #333;   position: absolute;   left: 0;   right: 0;   top: 3px;   width: 50px;   content: "*****" ; }
keep the JS as before.
(13.10.2022, 15:10)Daniel Wrote: Try this CSS
1234567891011121314
Hey thanks!
almost worked look
however it is still showing the text
do you have two elements on top of each other?
Try this CSS:
12345678910111213
.password.item-value {   color: transparent !important;   width: 50px; } .password.item-value:after {   color: #333;   position: absolute;   left: 3px;   right: 0;   top: 8px;   width: 50px;   content: "*****"; }
(14.10.2022, 06:07)admin Wrote: Try this CSS:
12345678910111213
Yes perfect! This worked! Thanks a lot  Big Grin Big Grin
