API, POST
So, I've run into a wall on something as ease as a POST function to a API.
How do I format the request to get this to work?
curl --request POST \
     --url https://api.easee.cloud/api/chargers/EH840488/settings \
     --header 'Authorization: Bearer *****MY TOKEN*****' \
     --header 'content-type: application/*+json' \
     --data '
     "dynamicChargerCurrent": 16
function WriteToEasee(request, request_body)
  request_url = 'https://api.easee.cloud/api/' .. request
  local response_body = {}
  local request_body = ""
  local body, code, hdrs, stat = ssl.https.request{
    url = request_url;
    method = "POST";
    headers =
      ["Content-Type"] = "application/json";
      ["Authorization"] = "Bearer " .. API_Token;
    source = ltn12.source.string(request_body);
    sink = ltn12.sink.table(response_body);
  log(code)
  if code == 200 then
    ret = table.concat(response_body)
    ret = json.pdecode(ret)
    return ret
    --API_Token = GetToken() -- request a new token
dynCurr = 10
-- Dynamic current setting.
WriteToEasee('chargers/' .. ChargerID  .. '/settings', "dynamicChargerCurrent" .. dynCurr)
This is as far as I've gotten. I'm getting code 400, request is missing or has invalid values.
I guess it's a small matter, but i have not worked with POST functions before.
Request is missing Content-Length header:
["Content-Length"] = #request_body,
(01.11.2022, 07:19)admin Wrote: Request is missing Content-Length header:
Still 400:
  local content_length
  if type(request_body) == "string" then
    content_length = #request_body
    request_body = ""
    url = request_url;
    method = "POST";
    headers =
  log(code)
  if code == 200 then
    return ret
dynCurr = 10
Still 400:
    request_body = ""
    url = request_url;
    method = "POST";
    headers =
  log(code)
  if code == 200 then
    return ret
dynCurr = 10
Could it be a mismatch with this?
In the docs it says this:  "{\"dynamicChargerCurrent\":16}"
You need to encode your request data using JSON:
body = require('json').encode({ dynamicChargerCurrent = dynCurr })
WriteToEasee('chargers/' .. ChargerID  .. '/settings', body)
(01.11.2022, 07:27)admin Wrote: You need to encode your request data using JSON:
BINGO, Thank You, as always Smile
Only thing missing now is the response_body.. that one is blank.
