Mosaic widget editor numeric element
Im designing a custom widget and added an element for showing and changing a numeric value.
I see however that the element itself does not show the floating number but an integer.
The value shows 40 whereas the real value is 39.99
Is there a way to change this?
Thanks in advance.
Use the +/- element and set step to 0.1
(02.11.2022, 18:02)Daniel Wrote: Use the +/- element and set step to 0.1
Hi Daniel, I take advantage from this post to ask you if it is possible add at this object (+/-) a way to change the dimensions, something it is very big versus the other objects in the widgets creator.
Best regards Cristian
It can be adjusted via CSS:
12345678910111213
.widget-custom .temperature .value {   height: 40px;   line-height: 40px;   width: 80px; } .widget-custom .temperature .ctrl {   height: 30px;   width: 30px; } .widget-custom .temperature .ctrl .fa {   line-height: 30px;   font-size: 20px; }
(03.11.2022, 07:43)admin Wrote: It can be adjusted via CSS:
12345678910111213
Hi Daniel,
Thx for the tip, however the resolution is still not high enough.
I need 0.01 and even 0.001 resolution, I ended up designing it in Visu and that works perfectly.
Maybe an improvement to add an option to choose how much decimal places must be shown in mosaic.
Thanks!
