Scheduler read
how can I read the time table of a schedule to activate an external function some times before ?
( if there is a time to turn on a light al 10.00 o'clock I 'd like activating the termostate 30' before of it )
Alberto
KNX Advanced Partner + Tutor
(09.11.2022, 16:28)toujour Wrote: Hi,
Alberto
Hi Alberto,
Take a look at this, maybe it can help you.
https://forum.logicmachine.net/showthrea...duled.time
Best regards Cristian
Create a scheduled script that runs every minute. Make sure that the event you want to check has a unique name.
now = os.date('*t') now_mins = now.hour * 60 + now.min name = 'unique event name' evt = db:getrow('SELECT * FROM scheduler_events WHERE name=?', name) if evt then   evt_mins = evt.start_hour * 60 + evt.start_min   delta = evt_mins - now_mins   if delta == 30 then     -- 30 minutes before the event     -- do something here   end else   alert('event not found') end
