attempt to compare number with nil
Keep getting this error and I'm not sure how to get rid of it.
3/0/41 is DPT1
3/0/21 is a percentage value. I have tried using DPT9 and now using DPT5
3/0/21 is mostly at 0%, I've tried to manually set the GA to 0 to be sure it's not nil.
Resident script:9: attempt to compare number with nil stack traceback:
local auxswitch = grp.getvalue('3/0/41') local auxstatus = grp.getvalue('3/0/21') if auxswitch == true then   grp.write('3/0/57', 0) elseif (auxswitch == false and auxstatus == 0) then   grp.write('3/0/57', 1) elseif (auxswitch == false and auxstatus >= 1 and auxstatus <= 33) then   grp.write('3/0/57', 2) elseif (auxswitch == false and auxstatus >= 34 and auxstatus <= 66) then   grp.write('3/0/57', 3) elseif (auxswitch == false and auxstatus >= 67 and auxstatus <= 100) then   grp.write('3/0/57', 4) end
Add log(auxstatus) after grp.getvalue and check what you get in Logs tab. You should use event script instead of resident. Add a common tag to 3/0/41 and 3/0/21 then map an event script to this tag.
Log gives me
* number: 0
Thanks for the tip regarding event.
Haven't realized that a tag can trigger event-script, always thought it had to be specific GA. Will migrate the script to event later.
