28.11.2022, 11:53
I'm having trouble with group addresses created on the logicmachine, when doing a GroupValueRead request from HomeAssistant.
I only encounter this with group addresses (not virtual) I made in the LM.
When a value changes by the LM itself the data is correctly send on the bus and updated in HA, but reading them doesn't work.
When I look into the objects logs I see that read requests are coming in but the decoded value, data type, object data are empty.
The source address 1.1.3 is the one from the HA.
When looking at the logs in HA I get 'knx bus did not respond in time' but as said only for the GroupAddresses which are created in the LM
Is this normal behaviour or is there something I need to change on the LM to get this working?
Thanks!
Thanks!
