Trend Logs
Good morning,
receiving the daily production by inverter, i would like to do logging per day, for example at 11p.m.. The inverter gives us the daily total production, but in Trade logs, there is the option of logging maximum per hour. Is there a setting for this?
Thank you in advance,
Chris Balatis
If you look on the month view then you will have daily data.
Good morning,
I attach you two screenshots with our problem.
As you can see, with the specific example :
When it is selected "per Day" on 7th Dec, the total ammount is 17.48kWh.
When it is selected "per Month", for the 7th, it is shown up 7.78kWh.
Why is this happening?
Thank you in advance.
Best Regards,
Chris Balatis
what type of trend is this?
It is absolute value.
Then the value shown there is correct as it is average of the day. Use counter and it will show correctly.
