19.01.2023, 11:13
I was wondering, we have a building with 20 rooms that have a master wall mounted old mechanical thermostat.
We would like to change this to
CTM https://ctmlyng.no/produkter/mtouch-one-alu-op/ or
Elko https://proff.elko.no/smart-super-termos...y2970.html
Do you have support for this in LM, i cant find them on list.
We would like to see room temperatur, change set point, heat on/off and calender on locally them if possible so that they work stand alone in case of communication problems.
If not possible to adjust calender we can use calender in LM to change set point up and down
Do this sound like an solution to use LM as user visu to this?
