Search schedulers
Received this function some years ago from support.
It should find  on and off time for a specific scheduled GA
I get this error when I try to run it.
User script:21: bad argument #1 to 'ipairs' (table expected, got string)
stack traceback:
[C]: in function 'ipairs'
User script:21: in function 'findtime'
User script:33: in main chunk
function findtime(addr, value)   local obj, file, data   -- read data from cache file   file = '/tmp/lm-scheduler-' .. os.date('%Y%m%d') .. '.lua'   data = io.readfile(file)   -- cache file missing, stop   if not data then     return   end   -- try decoding cache   data = serialize.decode(data)   if type(data) ~= 'table' then     return   end   obj = knxlib.encodega(addr)   for time, events in pairs(data) do     for _, event in ipairs(events) do       if event.object == obj and value == toboolean(event.value) then         return time       end     end   end end ------------------------------------------ t1 = findtime('1/0/1', true) t2 = findtime('1/0/1', false)
(07.02.2023, 08:28)CarlS Wrote: Hi,
stack traceback:
argument "event" is not a table. log it and see whats inside. also log "data"
Modify the function like this:
function findtime(addr, value)   local obj, file, data   -- read data from cache file   file = '/tmp/lm-scheduler-' .. os.date('%Y%m%d') .. '.lua'   data = io.readfile(file)   -- cache file missing, stop   if not data then     return   end   -- try decoding cache   data = serialize.decode(data)   if type(data) ~= 'table' then     return   end   obj = knxlib.encodega(addr)   for time, events in pairs(data) do     if type(time) == 'number' then       for _, event in ipairs(events) do         if event.object == obj and value == toboolean(event.value) then           return time         end       end     end   end end
