I have a script to create the curve easily.
It work perfect/
My problem is about password, if my customer use special caracter like @ it doesn't work.
I tried to replace with %40 ...
ASCII/UNICODE... @ %40 @ Alt 64
example:
password= xxxXxxx%40yyyYyy
without sucess.
Any help apreciated
It work perfect/
example:
without sucess.
Any help apreciated
-- creer la courbe
function createCurve(adresse, classement)
  if adresse then
    require('json')
    require('socket.url')
    require('socket.http')
    -- parameters
    daily = 365*24*60 -- 1 day
    daily1year = 365*24*12 -- 365 day
    daily2year = 2*365*24*12 -- 365 day
    year5_d = 5*365 -- 5 year
    trend_type = 'C' -- C is counter, D is counter with neg. delta, G is absolute value
    object = adresse
    if grp.find(adresse) then
      --separe nom du cpt pour mettre que le libelle dans nom des courbes
      nom_compteur=grp.alias(adresse)
      nom_compteur_split=string.split(nom_compteur,'-')
      -- si pas total, on separe
      if nom_compteur_split[4] then
        zone=string.gsub(nom_compteur_split[2],'CPTTD_','')
        nom_compteur=zone..'-'..nom_compteur_split[5]
      trend = {
        object = knxlib.encodega(object), -- object id in db
        name = nom_compteur, -- trend name
        type = trend_type,
        resolution = 60, -- every 5 minute
        precision = 1, -- floating point precision
        count_resolution = 365*24*12, -- 1 year
        count_daily = 5*365, -- 5 years
        category = classement
      data = json.encode(trend)
      post = 'data=' .. socket.url.escape(data)
            --auth=require('mime').b64('admin:'..password)
      --res, err = socket.http.request('http://'..auth..'@127.0.0.1/scada-main/trends/save', post)
      res, err = socket.http.request('http://admin:'..password..'@127.0.0.1/scada-main/trends/save', post)
      sleep(1)
      if err then
        log(res, err)
SE ECO EXPERT
SE ECO EXPERT
