23.06.2021, 09:21
Use grp.create: https://openrb.com/docs/lua.htm#grp.create
API esios ree
23.06.2021, 09:21
23.06.2021, 10:59
thanks for the reply.
Would it be possible to do it automatically, specifying a minimal virtual object up to a maximum? regards
16.02.2023, 08:01
hello, esios change the header for autentification in their API, from
Code: curl "https://api.esios.ree.es/indicators" -X GET Code: curl "https://api.esios.ree.es/archives" -X GET \ In the script of this post I try to change: Quote:--Token=('Token token=\34'..token..'\34') Code: body, code, hdrs, stat = https.request ({ --Llamada HTTP formada por URL+metodo+cabecera but, the return code is 401, error with authentification Anyone was able to update the request to new way? thanks for your help
16.02.2023, 12:54
Does it work if you send the same request using curl?
yes, old curl (valid until end of this month) and new curl return the json. But I am not able make it works properly
curl "https://api.esios.ree.es/indicators/1001?start_date=15-02-2023T00%3A00&end_date=15-02-2023T23%3A50&geo_ids[]=8741" -X GET \ -H "Accept: application/json; application/vnd.esios-api-v1+json" \ -H "Content-Type: application/json" \ -H "Host: api.esios.ree.es" \ -H "Authorization: Token token=\"xxxxxxxxxxxxxxxxxxxxx\"" \ -H "Cookie: " curl "https://api.esios.ree.es/indicators/1001?start_date=15-02-2023T00%3A00&end_date=15-02-2023T23%3A50&geo_ids[]=8741" -X GET \ -H "Accept: application/json; application/vnd.esios-api-v1+json" \ -H "Content-Type: application/json" \ -H "Host: api.esios.ree.es" \ -H "x-api-key:\"xxxxxxxxxxxxxxxxxxxxx\"" \ -H "Cookie: " (16.02.2023, 14:33)jose_dli Wrote: yes, old curl (valid until end of this month) and new curl return the json. But I am not able to make it works properly
16.02.2023, 14:37
Can you send your access token via PM?
17.02.2023, 09:25
Thanks. It seems that their API does not accept the key when there's a space in the key header: x-api-key: "...". HTTP library always sends headers this way. Can you contact them and ask if they can fix it on their side?
17.02.2023, 11:57
thanks a lot, I'll write them, if any news, I'll come back
21.02.2023, 13:10
the problem was the quotes in the token and that esios had two servers to make test.
The way is as follow: Code: token='xxxxxxxxxxxxxx' |
