Write a code from LM3, to send HTTP commands to a device to control it
Hi everybody! Please help me...please.!
I tried with it, but all failed...
Sad
I have a line:
http://100.100.100.9/send.htm?remote=sam...mand=power
And I need to write a script  used LM3, to send HTTP commands to a device to control it
That is Irtrans. Big Grin
Please help me.  Heart Heart  Thank you very much...All
This should do it. You will see the result of this request in "Logs" tab.
require('socket.http')
url = 'http://100.100.100.9/send.htm?remote=samsungtv&command=power'
res, err = socket.http.request(url)
log(res, err)
(18.09.2015, 06:11)admin Wrote: This should do it. You will see the result of this request in "Logs" tab.
log(res, err)
Thank admin. But I did try and error:  Sad
* arg: 1
 * nil
* arg: 2
 * string: No route to host
So why do it?..although, I typed in the address bar of Chorme still works
Please help me...Sad thank all  Heart
Check network settings in System Config -> Network -> Interfaces -> eth0. You have to set Gateway IP to your router IP, otherwise LogicMachine will only have access to devices in the same local network, but not outside.
Heart
Blush Heart ! Thank Admin and everyone.
I 've done . I succeeded!
Thank all!
(22.09.2015, 12:03)phongvucba Wrote: Blush Heart ! Thank Admin and everyone.
Thank all!
sr. ai đấy nhỉ?
Thank all!
Anh Phương mà!
sr. ai đấy nhỉ?
