12.03.2023, 10:15
my visu hung up in full-screen mode. Not so familiar with such kind of error. Where errors could be? Advice needed how to correct. How to switch wisu from start to full-screen mode taken from forum.
Part of log from Firefox:
Alex
Uncaught ReferenceError: grp is not defined
<anonymous> http://xxx.xxx.xxx.xxx/scada-vis/trends?id=1&mode=day:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=1&mode=day]trends:194:3[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=1&mode=day]trends:143:33[/url]
Uncaught (in promise) TypeError: Fullscreen request denied
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=1&mode=day:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=1&mode=day:155
[url=http://172.23.77.105/scada-vis/trends?id=1&mode=day]trends:143:34[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=9&mode=day&_nc=ve67m1ltel:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=9&mode=day&_nc=ve67m1ltel]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj]trends:194:3[/url]
<anonymous> http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069:194
jQuery 4
[url=http://172.23.77.105/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069]trends:194:3[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj]trends:143:33[/url]
Request for fullscreen was denied because Element.requestFullscreen() was not called from inside a short running user-generated event handler. [url=http://172.23.77.105/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069]trends:143:33[/url]
fullScreen http://xxx.xxx.xxx.xxx/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o:155
[url=http://172.23.77.105/scada-vis/trends?id=11&mode=day&_nc=y4thdcel4o]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k:155
[url=http://172.23.77.105/scada-vis/trends?id=25&mode=day&_nc=69je6gka89k]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck:155
[url=http://172.23.77.105/scada-vis/trends?id=42,43&mode=day&multiple=1&_nc=55av2rppwck]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn:155
[url=http://172.23.77.105/scada-vis/trends?id=15&mode=day&_nc=lxx2kqezjn]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and:155
[url=http://172.23.77.105/scada-vis/trends?id=13&mode=day&_nc=kvlbva4and]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j:155
[url=http://172.23.77.105/scada-vis/trends?id=20&mode=day&_nc=6jcjm319w4j]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b:155
[url=http://172.23.77.105/scada-vis/trends?id=16&mode=day&_nc=lm27jy85y2b]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8:155
[url=http://172.23.77.105/scada-vis/trends?id=21&mode=day&_nc=u4vxoi4qyh8]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8:155
[url=http://172.23.77.105/scada-vis/trends?id=22&mode=day&_nc=ntl7m71k7k8]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj:155
[url=http://172.23.77.105/scada-vis/trends?id=23&mode=day&_nc=ndmmcl8kesj]trends:143:34[/url]
fullScreen http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069:143
StartUserInput http:// xxx.xxx.xxx.xxx/scada-vis/trends?id=24&mode=day&_nc=rtynlp4s069:155
