Scene on Mosaic
Good afternoon,
A simple info.... Is it possible create event script to run scene created in mosaic?
Best regards Cristian
Try this. Change title variable to the title of your scene widget (case sensitive). If you have multiple scenes with the same title then this script will run all such scenes.
123456789101112131415161718192021222324
title = 'my scene' config = storage.exec('get', 'mosaic30:config:0') config = require('json').decode(config) function checkwidget(widget)   if widget.type ~= 'user_scene' then     return   elseif widget.title ~= title then     return   end   for addr, value in pairs(widget.settings.objects) do     grp.write(addr, value)   end end for _, floor in ipairs(config.floors or {}) do   for _, room in ipairs(floor.rooms or {}) do     for _, widget in ipairs(room.widgets or {}) do       checkwidget(widget)     end   end end
(30.03.2023, 05:55)admin Wrote: Try this. Change title variable to the title of your scene widget (case sensitive). If you have multiple scenes with the same title then this script will run all such scenes.
Thanks admin, I will try and I let you know.
Hi admin,
tested and it works, thank you so much.
Could I suggest an improve?
It could be interesting add some delay between a command and other. It could be useful for scene that interest TV command for example.
BR Cristian
