Get temperature data from web page
I want to get a temperature from a web page (Sea and water temperature) and send it to a group address. The temperature i want is "Vatten" for "Yngsjö havsbad".
The closest i could find in the forum was this script, post #5, Forum post. But i get stuck when it comes to "find matching string and fetch the data you want with".
Does anyone have any ideas how this could be done? Any tips or pointing me in a better direction?
Best regards //Simon
require('ssl.https')
data = ssl.https.request('https://www.havochvatten.se/badplatser-och-badvatten/vattenprov-badtemperatur/vattentemperatur-och-kvalitet-pa-badvatten-pa-sydkusten.html')
log(data)
Try this:
123456789101112131415
url = 'https://www.havochvatten.se/badplatser-och-badvatten/vattenprov-badtemperatur/vattentemperatur-och-kvalitet-pa-badvatten-pa-sydkusten.html' data = require('socket.http').request(url) lines = data:split('\n') for _, line in ipairs(lines) do   if line:find('<tr><td headers="head11">') then     location = line:match('<tr><td headers="head11">([^,]+)')     watertemp = tonumber(line:match('<td headers="head13">([^ ]+).+</td>'))     airtemp = tonumber(line:match('<td headers="head14">([^ ]+).+</td>'))     location = location:gsub('&#xAD;', '')     log(location, watertemp, airtemp)   end end
Great, but how do i split up the log to send the value i want?
I tried this code, it sends a value but not corectly. It first sends the value 5,6 310 times, then 13 other values once. At least all the values are from the correct table.
1234567891011121314151617
url = 'https://www.havochvatten.se/badplatser-och-badvatten/vattenprov-badtemperatur/vattentemperatur-och-kvalitet-pa-badvatten-pa-sydkusten.html' data = require('socket.http').request(url) lines = data:split('\n') for _, line in ipairs(lines) do   if line:find('<tr><td headers="head11">') then     location = line:match('<tr><td headers="head11">([^,]+)')     watertemp = tonumber(line:match('<td headers="head13">([^ ]+).+</td>'))     airtemp = tonumber(line:match('<td headers="head14">([^ ]+).+</td>'))     location = location:gsub('&#xAD;', '')     log(location, watertemp, airtemp)   end badtemp = watertemp grp.write('10/5/101', badtemp) end
Which values exactly do you want and in which group addresses?
(11.04.2023, 14:02)admin Wrote: Which values exactly do you want and in which group addresses?
I want the first value (5 ℃) from this row: Yngsjö havsbad, Kristian­stad 5 ℃ 8.1 ℃ (see attached pictures)
Group adress: 10/5/101
4.9 ℃
6.5 ℃
Try this:
url = 'https://www.havochvatten.se/badplatser-och-badvatten/vattenprov-badtemperatur/vattentemperatur-och-kvalitet-pa-badvatten-pa-sydkusten.html' data = require('socket.http').request(url) pos = data:find('Yngsjö havsbad') watertemp = tonumber(data:match('<td headers="head13">([^ ]+).+</td>', pos)) grp.checkwrite('10/5/101', watertemp)
Thanks, works perfectly!
//Simon
Since you kindly helped me last time, they've change the website and now i have to update the script..
Is anyone willing to help me, again?
Source URL
Value marked with blue.
(23.08.2023, 13:49)Ohmarn Wrote: Hi,
Source URL
Used ChatGTP for this:
12345678910111213141516171819202122232425262728293031
url = 'https://www.havochvatten.se/badplatser-och-badvatten/vattenprov-badtemperatur/vattentemperatur-och-kvalitet-pa-badvatten-pa-sydkusten.html' data = require('socket.http').request(url) -- Function to extract the temperature for a specific location local function extractTemperatureForLocation(html, locationName)     local locationStartIdx, locationEndIdx = html:find(locationName)     if not locationStartIdx then         return nil     end     local temperatureStartIdx, temperatureEndIdx, temperature = html:find("(%d+%.%d+)°C", locationEndIdx)     if not temperatureStartIdx then         return nil     end     return temperature end -- Location name to search for local locationName = "Yngsjö havsbad" -- Extract temperature for the specific location local temperature = extractTemperatureForLocation(data, locationName) if temperature then     -- Print the extracted temperature     --log(locationName .. " temperature: " .. temperature .. "°C")       grp.checkwrite('10/5/101', temperature) else     log(locationName .. " temperature not found.") end
