Script to track Day Ahead prices for electricity on the ENTSOE-E Platform
This script will fetch the daily prices from the ENTSO-E Transparency platform for your country.
It will also give the average price of the day, percentages based on the lowest and highest price for all prices of the day and the group address of the lowest and highest price object, so the lowest price is 0% while the highest price is 100%. A value of 34% means you will pay 34% more than what is possible on another time of the day.
Apart from this daily data, you can do a trend log on the average price, which can then be processed monthly to get a monthly average, along with your consumption tracking you are able to calculate a more precise price per kWh, certainly if your country makes use of some sort of 'capacity tariff'.
All useable values e.g. prices, percentages, objects group addresses of lowest and highest price and average, are stored in virtual objects for use in other scripts.
For prices, 24 objects are needed, for the percentages 24 objects are needed, and 3 objects for lowest, highest and average
Visual of objects
Prerequisites
  • You must register a free account on the ENTSO-E Transparency Platform and request a personal API key
  • Scheduled Script at 0 minute, 14 hours, daily, every day, every month
  • The way (virtual) objects for price and percentage are numbered gives you the advantage to see the hours based on the group address, see further
  • The first object for storing the prices must start with 0 (eg.: 34/1/0 or 32/3/0,...)
    So object 32/1/4 represents the price for hour 04:00, 32/1/20 the price for hour 20:00
    Prices are in €/MWh
    14.4 byte floating point
  • The first object for storing the percentages must start with 0 (eg.: 34/1/0 or 32/3/0,...)
    So object 33/1/4 represents the percentage for hour 04:00, 33/1/20 the percentage for hour 20:00
  • The objects for lowest, highest and average price are 14.4 byte floating point
    Prices are in €/MWh
  • The object for lowest and highest groupaddress must be 16.14 byte ASCII string
Variables
  • fetchfortommorow: default TRUE, normally prices are fetched for tommorow making it more useable, but if you want to fetch prices for today set this to FALSE
  • SecurityTokenAPI: your personal API security token that you can request by making a free account on the ENTSOE-E Transparency Platform and by sending an email to them.
  • EntsoeDomain: the string to be used for your country, you can find it here in this API manual
  • StartGrpAddr: The 2 first numbers of the objects to be used for prices including seperation symbol, eg: 34/2 or 32/1
  • StartGrpAddrPercent: The 2 first numbers of the objects to be used for percentages including seperation symbol, eg: 34/2 or 32/1
  • SecondsPastTillRefetch: Safety swith to prevent to much polling if cron job is misconfigured (prevents you from being blocked on the platform) Default is 39600 seconds, being 11 hours
  • StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes: Prevents polling data when it's not possible. Since prices for the day ahead are published at 13:00 hours the current day, it's no use to run this script outside certain hours.
  • objaddrCheckUpdateTime: Object used to check the last update time, default the second price object being x/1/1
  • objaddrLowestprice: Object used to store lowest price
  • objaddrHighestprice: Object used to store highest price
  • PrintLOG: Default FALSE, set TRUE for troubleshooting
local fetchfortommorow = true -- true for tommorow, false for today local SecurityTokenAPI = 'your-personal-key' -- your personal security token, get it at entsoe transparency platform local EntsoeDomain = '10YBE----------2' -- find your domain for the country you are living at https://transparency.entsoe.eu/content/static_content/Static%20content/web%20api/Guide.html#_load_domain local StartGrpAddr = '34/1' -- group addresses used to store the €/MWh prices per hour, x/x/0 is 00:00 hour, x/x/1 is 01:00 hour local StartGrpAddrPercent = '34/2' -- group addresses to store calculated pecentages for the hours, x/x/0 is 00:00 hour local SecondsPastTillRefetch =  39600 -- seconds that must be past till new refetch will be done, default 39600 seconds, is 11 hours local StartTimeHours=13 -- start time in which fetching is allowed, used in function IsTimeBetween local StartTimeMinutes=00 -- start minutes in which fetching is allowed, used in function IsTimeBetween local StopTimeHours=23 -- stop time in which fetching is allowed, used in function IsTimeBetween local StopTimeMinutes=59 -- stop minutes in which fetching is allowed, used in function IsTimeBetween local objaddrCheckUpdateTime = '34/1/1' -- object to check last updated date from local objaddrLowestprice = '34/1/26' -- object to store groupaddress of lowest price of the day local objaddrHighestprice = '34/1/27' -- object to store groupaddress of highest price of the day local PrintLOG = false -- logging   -- https://stackoverflow.com/questions/35402992/how-to-check-if-current-time-is-between-two-others   -- Function to check if current time is between 2 other defined times   -- Returns true if time is between 2 other times   local function getMinutes(hours, minutes)       return (hours*60)+minutes   end   local function IsTimeBetween(StartH, StartM, StopH, StopM, TestH, TestM)       if (StopH < StartH) then -- add 24 hours if endhours < starthours           local StopHOrg=StopH           StopH = StopH + 24           if (TestH <= StopHOrg) then -- if endhours has increased the currenthour should also increase               TestH = TestH + 24           end       end       local StartTVal = getMinutes(StartH, StartM)       local StopTVal = getMinutes(StopH, StopM)       local curTVal = getMinutes(TestH, TestM)       return (curTVal >= StartTVal and curTVal <= StopTVal)   end      local function IsNowBetween(StartH,StartM,StopH,StopM)     local time = os.date("*t")       if PrintLOG then     log(time.hour, time.min) --check if time is correct, if not change to os.date("!*t") for UTC time     end     return IsTimeBetween(StartH, StartM, StopH, StopM, time.hour, time.min)   end     if PrintLOG then       log(IsNowBetween(StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes))   end   -- https://stackoverflow.com/questions/35402992/how-to-check-if-current-time-is-between-two-others objectupdatedate = (grp.find(objaddrCheckUpdateTime).updatetime) -- get update date for chosen object diff = os.difftime(os.time(),objectupdatedate) -- difference between current time and objectupdatetime in seconds if diff > SecondsPastTillRefetch then --check if last run was more than x seconds ago https://www.google.com/search?q=seconds+to+hours       if PrintLOG then           log('more than '..SecondsPastTillRefetch..' seconds since last run')     end     if (IsNowBetween(StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes)) then --check if current time is between hours that data can be fetched         if PrintLOG then                 log('data can be fetched')       end             -- https://forum.logicmachine.net/showthread.php?tid=4268&highlight=entsoe       if fetchfortommorow then         date = os.date('%Y%m%d', os.time() + 86400) -- date is tommorow, default setting       else         date = os.date('%Y%m%d') --date is today       end       periodstart = date .. '0000'       periodend = date .. '2300'       log(date)       url = 'https://web-api.tp.entsoe.eu/api?securityToken='..SecurityTokenAPI..'&' ..         'documentType=A44&in_Domain='..EntsoeDomain..'&out_Domain='..EntsoeDomain..         '&periodStart=' .. periodstart .. '&periodEnd=' .. periodend       data, code = require('socket.http').request(url)       if not data or code ~= 200 then         log('request failed', data, code)         return       end       prices = {}       key = 0       callbacks = {         StartElement = function(p, tag)           if tag == 'TimeSeries' then             key = key + 1             prices[ key ] = {}           elseif tag == 'position' then             state = 'position'           elseif tag == 'price.amount' then             state = 'price'           end         end,         EndElement = function(p, tag)           state = nil         end,         CharacterData = function(p, value)           value = value:trim()           if #value > 0 then             if state == 'position' then               position = tonumber(value)             elseif state == 'price' then               prices[ key ][ position ] = tonumber(value)             end           end         end       }       parser = require('lxp').new(callbacks)       parser:parse(data)       parser:close()       if key > 0 then         for i, price in pairs(prices[ 1 ]) do           j = i - 1 -- shifts the first key from 1 to 0, so the first groupaddress is x/x/0 for 00:00 hour, next is x/x/1 for 01:00 hour,etc...             grp.checkupdate(StartGrpAddr..'/' .. j, price) -- update objects with newest prices           --log('uur ' ..j..' prijs: ' ..price)         end                         -- https://stackoverflow.com/questions/69359710/how-to-get-the-smallest-number-in-a-table-with-lua                lowestprice = math.min(unpack(prices[ 1 ])) --lowest number in table                  highestprice = math.max(unpack(prices[ 1 ])) --highest number in table                   -- https://stackoverflow.com/questions/25835591/how-to-calculate-percentage-between-the-range-of-two-values-a-third-value-is                 --input = grp.getvalue('34/1/13')           for i, price in pairs(prices[ 1 ]) do          j = i - 1              percentage = ((price - lowestprice) * 100) / (highestprice - lowestprice)              --log('at hour '..j..':00 price is '..math.floor(percentage)..'% higher than lowest price today')         grp.checkupdate(StartGrpAddrPercent..'/' .. j, percentage) --update objects with newest percentages                   if lowestprice == price then               grp.checkupdate(objaddrLowestprice, StartGrpAddr..'/' .. j)           end           if highestprice == price then               grp.checkupdate(objaddrHighestprice, StartGrpAddr..'/' .. j)           end         end                 -- https://www.codegrepper.com/code-examples/lua/lua+calculate+average+number           function math.average(t)             local sum = 0                 for _,v in pairs(t) do -- Get the sum of all numbers in t               sum = sum + v             end             return sum / #t           end         grp.checkupdate('34/1/25', math.average((prices[ 1 ])))         end      -- https://forum.logicmachine.net/showthread.php?tid=4268&highlight=entsoe      else         if PrintLOG then             log('data cannot be fetched yet')       end       end  else   if PrintLOG then       log('data has already been fetched and updated, not necessary to re-fetch data')   end end
Thanks and gratitude to all the people that inspired me and where I used code from!
Feel free to optimise and extend!
I have need to schedule some consumption to the cheapest hours on night time, examples
1. "four cheapest hours in the row" or
2. "four cheapest hours in the night time"
What is the simple and robust way to handle this kind of scheduling? Anyone done this kind of solution based on this ENTSOE-E script?
1. prices must be a table where key is hour (0..23) and value is price. The resulting minhour variable is the first hour of the 4 hour period with the lowest prices.
minsum = math.huge minhour = 0 step = 4 for hour = 0, 24 - step do   sum = 0   for i = hour, hour + step - 1 do     sum = sum + prices[ i ]   end   if sum < minsum then     minsum = sum     minhour = hour   end end log(minhour)
2. For night prices use this, adjust night hours as needed (22 to 5 inclusive in this example).
for hour = 0, 23 do   if hour >= 22 or hour <= 5 then     nightprices[ #nightprices + 1 ] = {       hour = hour,       price = prices[ hour ]     }   end end table.sort(nightprices, function(a, b)   return a.price < b.price end) for i = 1, 4 do   item = nightprices[ i ]   log(item.hour, item.price) end
Good work @tigi!  Cool
I usually add automatic group address creation on this kind of programs so when you copy code to a new LM, you can run this program within seconds.
Also edited line 151 (group address was hard coded) and removed Average, Min and Max price Group addresses because these gonna generated automatically...
Now you need basically edit only three group address:  StartGrpAddr,  StartGrpAddrPercent and objaddrCheckUpdateTime + activate "create_addresses" on first time when running the code.
I have some ideas to create controlling part (solar inverters and battery charging/discharging) on top of this code but let's see when I have time to do that. Gonna share the results then...
local fetchfortommorow = true -- true for tommorow, false for today local SecurityTokenAPI = 'your-api-key-in-here' -- your personal security token, get it at entsoe transparency platform local EntsoeDomain = '10Y1001A1001A39I' -- find your domain for the country you are living at https://transparency.entsoe.eu/content/static_content/Static%20content/web%20api/Guide.html#_load_domain local StartGrpAddr = '60/1' -- group addresses used to store the €/MWh prices per hour, x/x/0 is 00:00 hour, x/x/1 is 01:00 hour local StartGrpAddrPercent = '60/2' -- group addresses to store calculated pecentages for the hours, x/x/0 is 00:00 hour local SecondsPastTillRefetch =  39600 -- seconds that must be past till new refetch will be done, default 39600 seconds, is 11 hours local StartTimeHours=13 -- start time in which fetching is allowed, used in function IsTimeBetween local StartTimeMinutes=00 -- start minutes in which fetching is allowed, used in function IsTimeBetween local StopTimeHours=23 -- stop time in which fetching is allowed, used in function IsTimeBetween local StopTimeMinutes=59 -- stop minutes in which fetching is allowed, used in function IsTimeBetween local objaddrCheckUpdateTime = '60/1/0' -- object to check last updated date from --local objaddrAverageprice = '60/1/25' -- object to store average value --local objaddrLowestprice = '60/1/26' -- object to store groupaddress of lowest price of the day --local objaddrHighestprice = '60/1/27' -- object to store groupaddress of highest price of the day local PrintLOG = false -- logging local create_addresses = false --**********CREATE GROUP ADDRESSES****************** function createga(groupaddress,datatype2,name2)   exist = grp.alias(groupaddress)   if exist == nil then     address = grp.create({     datatype = datatype2,     address = groupaddress,     name = name2,     comment = 'Automatically created object',     units = '',     tags = { },     })   end end if create_addresses then   for i= 0, 27, 1 do     if i < 24 then       createga(StartGrpAddr ..'/'..i,dt.float32,'Electric - Entsoe day ahead  ' .. i)       createga(StartGrpAddrPercent ..'/'..i,dt.uint16,'Electric - Entsoe day ahead  ' .. i .. ' Percent')     elseif    i==25 then       createga(StartGrpAddr ..'/'..i,dt.float32,'Electric - Entsoe day ahead Average')     elseif i == 26 then       createga(StartGrpAddr ..'/'..i,dt.string,'Electric - Entsoe day ahead Lowest GrpAddr')      elseif i == 27 then       createga(StartGrpAddr ..'/'..i,dt.string,'Electric - Entsoe day ahead Highest GrpAddr')     end   end   os.sleep(2) end   -- https://stackoverflow.com/questions/35402992/how-to-check-if-current-time-is-between-two-others   -- Function to check if current time is between 2 other defined times   -- Returns true if time is between 2 other times   local function getMinutes(hours, minutes)       return (hours*60)+minutes   end   local function IsTimeBetween(StartH, StartM, StopH, StopM, TestH, TestM)       if (StopH < StartH) then -- add 24 hours if endhours < starthours           local StopHOrg=StopH           StopH = StopH + 24           if (TestH <= StopHOrg) then -- if endhours has increased the currenthour should also increase               TestH = TestH + 24           end       end       local StartTVal = getMinutes(StartH, StartM)       local StopTVal = getMinutes(StopH, StopM)       local curTVal = getMinutes(TestH, TestM)       return (curTVal >= StartTVal and curTVal <= StopTVal)   end      local function IsNowBetween(StartH,StartM,StopH,StopM)     local time = os.date("*t")       if PrintLOG then     log(time.hour, time.min) --check if time is correct, if not change to os.date("!*t") for UTC time     end     return IsTimeBetween(StartH, StartM, StopH, StopM, time.hour, time.min)   end     if PrintLOG then       log(IsNowBetween(StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes))   end   -- https://stackoverflow.com/questions/35402992/how-to-check-if-current-time-is-between-two-others objectupdatedate = (grp.find(objaddrCheckUpdateTime).updatetime) -- get update date for chosen object diff = os.difftime(os.time(),objectupdatedate) -- difference between current time and objectupdatetime in seconds if diff > SecondsPastTillRefetch then --check if last run was more than x seconds ago https://www.google.com/search?q=seconds+to+hours       if PrintLOG then           log('more than '..SecondsPastTillRefetch..' seconds since last run')     end     if (IsNowBetween(StartTimeHours, StartTimeMinutes, StopTimeHours, StopTimeMinutes)) then --check if current time is between hours that data can be fetched         if PrintLOG then                log('data can be fetched')       end             -- https://forum.logicmachine.net/showthread.php?tid=4268&highlight=entsoe       if fetchfortommorow then         date = os.date('%Y%m%d', os.time() + 86400) -- date is tommorow, default setting       else         date = os.date('%Y%m%d') --date is today       end       periodstart = date .. '0000'       periodend = date .. '2300'       log(date)       url = 'https://web-api.tp.entsoe.eu/api?securityToken='..SecurityTokenAPI..'&' ..         'documentType=A44&in_Domain='..EntsoeDomain..'&out_Domain='..EntsoeDomain..         '&periodStart=' .. periodstart .. '&periodEnd=' .. periodend       data, code = require('socket.http').request(url)       if not data or code ~= 200 then         log('request failed', data, code)         return       end       prices = {}       key = 0       callbacks = {         StartElement = function(p, tag)           if tag == 'TimeSeries' then             key = key + 1             prices[ key ] = {}           elseif tag == 'position' then             state = 'position'           elseif tag == 'price.amount' then             state = 'price'           end         end,         EndElement = function(p, tag)           state = nil         end,         CharacterData = function(p, value)           value = value:trim()           if #value > 0 then             if state == 'position' then               position = tonumber(value)             elseif state == 'price' then               prices[ key ][ position ] = tonumber(value)             end           end         end       }       parser = require('lxp').new(callbacks)       parser:parse(data)       parser:close()       if key > 0 then         for i, price in pairs(prices[ 1 ]) do           j = i - 1 -- shifts the first key from 1 to 0, so the first groupaddress is x/x/0 for 00:00 hour, next is x/x/1 for 01:00 hour,etc...             grp.checkupdate(StartGrpAddr..'/' .. j, price) -- update objects with newest prices           --log('uur ' ..j..' prijs: ' ..price)         end                        -- https://stackoverflow.com/questions/69359710/how-to-get-the-smallest-number-in-a-table-with-lua                lowestprice = math.min(unpack(prices[ 1 ])) --lowest number in table                  highestprice = math.max(unpack(prices[ 1 ])) --highest number in table                   -- https://stackoverflow.com/questions/25835591/how-to-calculate-percentage-between-the-range-of-two-values-a-third-value-is                 --input = grp.getvalue('34/1/13')           for i, price in pairs(prices[ 1 ]) do          j = i - 1              percentage = ((price - lowestprice) * 100) / (highestprice - lowestprice)              --log('at hour '..j..':00 price is '..math.floor(percentage)..'% higher than lowest price today')         grp.checkupdate(StartGrpAddrPercent..'/' .. j, percentage) --update objects with newest percentages                   if lowestprice == price then               grp.checkupdate(StartGrpAddr .. '/26', StartGrpAddr..'/' .. j)           end           if highestprice == price then               grp.checkupdate(StartGrpAddr .. '/27', StartGrpAddr..'/' .. j)           end         end                 -- https://www.codegrepper.com/code-examples/lua/lua+calculate+average+number           function math.average(t)             local sum = 0                 for _,v in pairs(t) do -- Get the sum of all numbers in t               sum = sum + v             end             return sum / #t           end         grp.checkupdate(StartGrpAddr .. '/25', math.average((prices[ 1 ])))         end      -- https://forum.logicmachine.net/showthread.php?tid=4268&highlight=entsoe      else         if PrintLOG then             log('data cannot be fetched yet')       end       end  else   if PrintLOG then       log('data has already been fetched and updated, not necessary to re-fetch data')   end end
