Synology surveillance Station webhook
I have configured the webhook on surveillance station and made a survstat.lp script to receive the webhook.
If i look in it i see this data after the test:
equire('apps') -- read POST data body = ngx.req.get_body_data() if body then -- decode data as JSON data = json.pdecode(body) -- check that data is a table if type(data) == 'table' then log(data) -- movement detected, you can check data.camera_id if you have multiple cameras if data.event_type == 'movement' then -- do something when movement happens end end end
How can i now use the movement to turn on a light?
You can use grp.write inside .lp scripts, just make sure that you have require('apps') before grp.write.
(13.04.2023, 10:12)KoBra Wrote: I have configured the webhook on surveillance station and made a survstat.lp script to receive the webhook.
I used this from the netatmo camera topic in my .lp script
I think i need to modify this part as i have no clue what i am getting in from synology
You're missing the starting <? tag in your .lp file. It should be like this:
<? require('apps') ...
