29.04.2023, 15:37
(This post was last modified: 02.05.2023, 07:53 by fleeceable.)
Hello!
In crypto world there is WeatherXM project where weather station owners gonna get tokens if they run station.
XM have also an API so I made a simple integration to get realtime weather data.
Go to address and find a weather station what is nearest for your location:
https://explorer.weatherxm.com/
Then zoom in and press on station and you'll see station device ID on address bar. Example: https://explorer.weatherxm.com/#87089b192ffffff
Change "Weather_device_ID" variable with your desired device ID.
Create scheduled script (what runs on every 15 minutes)...
If you run program on first time, enable "greate_ga" variable. That creates KNX variables automatically for you.
1234567891011121314151617181920212223242526272829303132333435363738394041424344454647484950515253545556
https = require("ssl.https")
require('json')
Weather_device_ID = '87089b192ffffff' --Device ID from https://explorer.weatherxm.com/
greate_ga = false --This variable enables group addresses automatic generation
main_ga = '32/1/' --Main group address of weather data
--**********CREATE GROUP ADDRESSES******************
function createga(groupaddress,datatype2,name2, units)
exist = grp.alias(groupaddress)
if exist == nil then
address = grp.create({
datatype = datatype2,
address = groupaddress,
name = name2,
comment = 'Automatically created object',
units = units,
tags = { },
if greate_ga then
createga(main_ga .. '1',dt.float16,'Weather - Temperature', '°C')
createga(main_ga .. '2',dt.float16,'Weather - Feels like temperature', '°C')
createga(main_ga .. '3',dt.uint8,'Weather - Humidity', ' %')
createga(main_ga .. '4',dt.float16,'Weather - Wind speed', ' m/s')
createga(main_ga .. '5',dt.float16,'Weather - Wind gust', ' m/s')
createga(main_ga .. '6',dt.uint8,'Weather - UV index', '')
createga(main_ga .. '7',dt.float16,'Weather - Precipitation', ' mm/h')
createga(main_ga .. '8',dt.float16,'Weather - Dew point', '°C')
createga(main_ga .. '9',dt.float16,'Weather - Solar irradiance', ' W/m2')
createga(main_ga .. '10',dt.float16,'Weather - Pressure', ' hPa')
createga(main_ga .. '11',dt.text,'Weather - Update time', '')
os.sleep(3)
log('---GROUP ADDRESSES HAS BEEN CREATED---')
data, code = https.request('https://api.weatherxm.com/api/v1/cells/' .. Weather_device_ID .. '/devices')
if data then
data = json.pdecode(data)
grp.checkupdate(main_ga .. 1, data[1]["current_weather"]["temperature"])
grp.checkupdate(main_ga .. 2, data[1]["current_weather"]["feels_like"])
grp.checkupdate(main_ga .. 3, data[1]["current_weather"]["humidity"])
grp.checkupdate(main_ga .. 4, data[1]["current_weather"]["wind_speed"])
grp.checkupdate(main_ga .. 5, data[1]["current_weather"]["wind_gust"])
grp.checkupdate(main_ga .. 6, data[1]["current_weather"]["uv_index"])
grp.checkupdate(main_ga .. 7, data[1]["current_weather"]["precipitation_accumulated"])
grp.checkupdate(main_ga .. 8, data[1]["current_weather"]["dew_point"])
grp.checkupdate(main_ga .. 9, data[1]["current_weather"]["solar_irradiance"])
grp.checkupdate(main_ga .. 10, data[1]["current_weather"]["pressure"])
grp.checkupdate(main_ga .. 11, data[1]["current_weather"]["timestamp"])
