HTTP Request HS zu w4k
Hello everyone
I would like to retrieve or write the internal address from a home server via http.
Read http and write to virtual group address
read
https://192.168.2.113/endpoints/call?key...XX&pw=XXXX
Write
maybe someone can help me?
Use this. The result / error will be visible in the Logs tab.
http = require('socket.http')
url = 'https://192.168.2.113/endpoints/call?key=CO@100_0_1&method=get&user=XXXX&pw=XXXX'
res, err = http.request(url)
log(res, err)
thanks works,
then I should actually get this value on the bus
url = 'https://192.168.2.113/endpoints/call?key=CO@100_0_1&method=get&user=xxx&pw=xxx'
log(res, err)
value = data
grp.checkwrite('32/1/2', value)
grp.checkwrite('32/1/2', res)
no sends 0
What do you get in Logs?
test 15.05.2023 10:52:17
* arg: 1
  * string: {"request": {"method": "get", "key": "CO@100_0_1"}, "code": 0, "type": "call", "data": {"value": 22.0}}
* arg: 2
  * number: 200
json = require('json')
res = json.pdecode(res)
grp.checkwrite('32/1/2', res.data.value)
works, thanks. to send do I have to turn the sript around?
Use an event script for writing:
value = event.getvalue()
url = 'https://192.168.2.113/endpoints/call?key=CO@100_0_1&method=set&value=' .. value .. '&user=XXXX&pw=XXXX'
log(res, err)
log() call is just for debugging, remove it if script is working correctly.
Thanks for the support
