Searching for an Integrator for a job - Modbus/LM5
Im looking to hire somebody with good experience of LM5 and Modbus TCP integration for a small job.
My criteria: Experienced in LM5, High knowledge in integration of Modbus devices. Independent and solution-oriented.
The job is to create visualization functionality for a Nibe S1255 heat pump in LM5 and add all modbus objects to LM5 and make a proper and reliable connection for long term use.
The heat pump is connected through Modbus TCP and the modbus registry is available. Remote connection / VPN can be setup for remote work and testing.
You need a registered company with VAT no to be hired for the job.
Payment by invoice. Budget is discussed in PM before start.
About me: Swedish Experienced integrator, High knowledge in System integration / building automation.
There is also very good chances for future projects together if we find a good collaboration.
Details is discussed in PM.
Looking forward to hear from you!
