Staircase logic with repeating off
Hello every one.
I use the Staircase logic Version 3.1 by Erwin van der Zwart.
I use this to start my lawn sprinkler and this one startet an EnOcean Rocker.
It works realy fine, but sometimes EnOcean Rocker does not receive the signal.
The Staircase logic is off but the EnOcean Rocker is still on. so i need to turn it manually off.
Is it possible to add a repeating off signal...like 2 or 3 times after ending the Staircase logic?
Tanks for you help!
Maybe you can add something like?
os.sleep(10)    --time delay of 10 seconds grp.write('my object', false) os.sleep(10)    --time delay of 10 seconds grp.write('my object', false) os.sleep(10)    --time delay of 10 seconds grp.write('my object', false)
replace my object with your groupadress / objectname
(03.06.2023, 10:57)Dré Wrote: Maybe you can add something like?
hey thanks
But in which line should I enter this??  -->  Staircase logic Version 3.1 by Erwin van der Zwart.
In "SET PARAMETERS" ???
Do you have a link to the post? post of Erwin
Maybe next time you need to post in that treat?
I think i should put it between line 101 and 102
grp.write(AddressOutput, false)         ValueOutput = false
what would look now
grp.write(AddressOutput, false) os.sleep(10)    --time delay of 10 seconds grp.write(AddressOutput, false) os.sleep(10)    --time delay of 10 seconds grp.write(AddressOutput, false) os.sleep(10)    --time delay of 10 seconds grp.write(AddressOutput, false)         ValueOutput = false
But does the EnOcean not have a feedback object, what you can use?
(04.06.2023, 12:19)Dré Wrote: Do you have a link to the post? post ofErwin
[quote pid="31053" dateline="1685881182"]
what would look now
[/quote]
OH  Confused sorry my mistake.
should I write here then?  post of Erwin
because this one didnt work.
because after the time has elapsed, it still only sends the off signal once.
the feedback doesn't help me because I start the logic from everywhere
