REACTOR and multiple gateways
I have a problem with the ETH and GSM network configuration, from a customer I need to send SMS and mail (so I use the reactor SIM) I also need to be able to create firewall rules on the ETH network managed by others so the gateway on the network I need to ensure that requests from remote clients are correctly redirected, I tried and also by configuring the gateway the SIM also receives sms.
I can rest assured that in the settings it is recommended not to set the gateway if GSM is used.
how can i solve the problem
A thousand thanks
If 3g/4g is enabled and connected then LM will use this connection for all external requests. You can still access LM via Ethernet / local IP. But Ethernet gateway won't be used.
