recovery img Spacelink HW V3.2?
Can you share the recovery image of the spacelink lss100200. I have a spacelink with both green LEDs blinking and the internal red LED blinking at the same.
Here you go, don't forgot to extract before usage
.gz   recovery-imx6-1g.img.gz (Size: 5.49 MB / Downloads: 25)
Thank you very much, it works correctly.
For HW: V3.1 Can I recover the same image?
Yes when having a HW 2 or 3 it should work (imx6)
(16.01.2024, 21:34)Erwin van der Zwart Wrote: Yes when having a HW 2 or 3 it should work (imx6)
Hi Erwin
Can I use same recovery in SpaceLynk and Wiser ?
I need to recover several Wiser
Use our recovery works on every hardware. Just make sure select correct CPU version.
https://kb.logicmachine.net/misc/reflash...ng-player/
(06.02.2024, 16:01)Daniel Wrote: Use our recovery works on every hardware. Just make sure select correct CPU version.
Thank you
Now they all run again
