29.06.2023, 18:09
Can you share the recovery image of the spacelink lss100200. I have a spacelink with both green LEDs blinking and the internal red LED blinking at the same.
recovery img Spacelink HW V3.2?
29.06.2023, 18:09
29.06.2023, 18:31
(This post was last modified: 29.06.2023, 18:33 by Erwin van der Zwart.)
Here you go, don't forgot to extract before usage
29.06.2023, 19:12
Thank you very much, it works correctly.
16.01.2024, 17:14
For HW: V3.1 Can I recover the same image?
16.01.2024, 21:34
(This post was last modified: 16.01.2024, 21:35 by Erwin van der Zwart.)
Yes when having a HW 2 or 3 it should work (imx6)
06.02.2024, 15:16
06.02.2024, 16:01
Use our recovery works on every hardware. Just make sure select correct CPU version.
https://kb.logicmachine.net/misc/reflash...ng-player/
06.02.2024, 16:33
(06.02.2024, 16:01)Daniel Wrote: Use our recovery works on every hardware. Just make sure select correct CPU version. Thank you Now they all run again |
