Time/Date to ETS
This is maybe not a LM question, but ill try anyway.
I have some pd11-knxs-flat-st where I need to use the HCL, then the sensor needs to know the time.
[Image: W7gHz9l.png]
I already have a Virtual Object with time and date to use in my visualization, can I use that?
[Image: pdmdXUk.png]
See this, you must use normal objects not virtual
https://openrb.com/example-write-lm2-dat...addresses/
Strange part is that it says DPT 10.001 but length is 8 bytes instead of 3 which is DPT 19.001 (date / time combined).
If it is actually 19.001 then see this thread: https://forum.logicmachine.net/showthread.php?tid=2035
Thanks both of you.
I can choose DPT10.001 also, then it changes to 3 bytes
[Image: v4zdKs9.png]
[Image: lbuZisz.png]
