ZigBee library
Hi at all,
I'm studying the ZigBee library, because I have a problem with a ZigBee device (his firmware it is bagged). The device sends status if the CMD arrives from LM but if I made changed in local, it doesn't send messages.
If I press the read command on the ZigBee interface status arrive. (See attached picture)
Here my request, is it possible by script simulate the pressing of that button?
Or which is the function in the library to request the device status?
Best regards Cristian
Full status read is done in the user UI part so it cannot be called from scripts. You can read attributes like LocalTemperature via a script:
zb = require('applibs.zigbee') addr = '0123456789abcdef' cluster = 0x0201 -- HvacThermostat attrs = { 'LocalTemperature' } res, err = zb.cmdsync('getnamedattributes', addr, cluster, attrs) log(res, err) if type(res) == 'table' and res.LocalTemperature then   temperature = res.LocalTemperature / 100   log(temperature) end
(13.09.2023, 10:57)CristianAgata Wrote: Hi at all,
Thank you so much
(13.09.2023, 11:56)admin Wrote: Full status read is done in the user UI part so it cannot be called from scripts. You can read attributes like LocalTemperature via a script:
Hi admin,
i'm testing the code, this is the log on the zigbee device
Manufacturer: Rti-Tek Model: Thermostat Firmware version: 2.2 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - PowerCfg (1) - Identify (3) - HvacThermostat (513) - HaDiagnostic (2821) - 64527 Output clusters - Time (10) - Ota (25) Reported attributes - heatingstatus: true - localtemperature: 26.20 - occupiedheatingsetpoint: 27.00 - systemmode: 1
I have filled my script in this way;
zb = require('applibs.zigbee') --log(zb) addr = '84fd27fffea5ec1c' cluster = 0x0201 -- HvacThermostat attrs = { 'heatingstatus' } res, err = zb.cmdsync('getnamedattributes', addr, cluster, attrs) log(res, err) if type(res) == 'table' and res.heatingstatus then   --temperature = res.LocalTemperature / 100   log(res.heatingstatus) end
In log I have this error:
* arg: 1
  * nil
* arg: 2
  * string: .../tmp.VsS0GSqtJq/files/store/daemon/zigbee/zigbee/zcl.lua:167: attempt to index a nil value
Where am I wronging?
You need to read the SystemMode attribute. If it's not zero then the heating is enabled. You can read multiple attributes from the same cluster by adding multiple names to the attrs table.
In the next app version read response will be treated the same as reporting that devices send from time to time. This means that mapped objects will be updated automatically. It will be enough to send the attribute read request without adding any extra code for parsing values.
(15.09.2023, 05:14)admin Wrote: You need to read the SystemMode attribute. If it's not zero then the heating is enabled. You can read multiple attributes from the same cluster by adding multiple names to the attrs table.
Is there any way to know attributes names?
Here's a list of clusters and respective attributes.
Basic (0x0000)   ZCLVersion   HwVersion   ManufacturerName   ModelId   SwBuildId PowerCfg (0x0001)   BatteryVoltage   BatteryLevel OnOff (0x0006)   OnOff LevelCtrl (0x0008)   CurrentLevel   OnOffTransitionTime   OnLevel   StartUpCurrentLevel LightingColorCtrl (0x0300)   CurrentHue   CurrentSaturation   RemainingTime   CurrentX   CurrentY   ColorTemperature   ColorMode   EnhancedCurrentHue   EnhancedColorMode   ColorCapabilities   ColorTempPhysicalMin   ColorTempPhysicalMax LightingBallastCfg (0x0301)   PhysicalMinLevel   PhysicalMaxLevel   MinLevel   MaxLevel   ControlMode MsIlluminanceMeasurement (0x0400)   MeasuredValue MsTemperatureMeasurement (0x0402)   MeasuredValue   TemperatureSensorType MsPressureMeasurement (0x0403)   MeasuredValue MsRelativeHumidity (0x0405)   MeasuredValue AnalogInput (0x000C)   Description   MaxPresentValue   MinPresentValue   OutOfService   PresentValue   Reliability   RelinquishDefault   Resolution BinaryInput (0x000F)   PresentValue HvacThermostat (0x0201)   LocalTemperature   OutdoorTemperature   Occupancy   AbsMinHeatSetpointLimit   AbsMaxHeatSetpointLimit   AbsMinCoolSetpointLimit   AbsMaxCoolSetpointLimit   PICoolingDemand   PIHeatingDemand   HVACSystemTypeConfiguration   LocalTemperatureCalibration   OccupiedCoolingSetpoint   OccupiedHeatingSetpoint   UnoccupiedCoolingSetpoint   UnoccupiedHeatingSetpoint   MinHeatSetpointLimit   MaxHeatSetpointLimit   MinCoolSetpointLimit   MaxCoolSetpointLimit   MinSetpointDeadBand   RemoteSensing   ControlSequenceOfOperation   SystemMode   AlarmMask   ThermostatRunningMode HvacFanCtrl (0x0202)   FanMode   FanModeSequence HaElectricalMeasurement (0x0B04)   RmsVoltage   RmsCurrent   HaActivePower   HaReactivePower   HaApparentPower   PowerFactor   VoltageMultiplier   VoltageDivisor   CurrentMultiplier   CurrentDivisor   HaPowerMultiplier   HaPowerDivisor SeMetering (0x0702)   CurrentSummDelivered   SePowerMultiplier   SePowerDivisor   SeActivePower SsIasZone (0x0500)   ZoneState   ZoneType   ZoneStatus   IasCieAddr   ZoneId   ZoneSensitivityLevel   DetectionTimeout ClosuresDoorLock (0x0101)   LockState   LockType   ActuatorEnabled   DoorState ClosuresWindowCovering (0x0102)   WindowCoveringType   PhysicalClosedLimitLift   PhysicalClosedLimitTilt   CurrentPositionLift   CurrentPositionTilt   NumberOfActuationsLift   NumberOfActuationsTilt   ConfigStatus   CurrentPositionLiftPercentage   CurrentPositionTiltPercentage   Mode   LiftDriveUpTime   LiftDriveDownTime   TiltOpenCloseAndStepTime   TiltPositionPercentageAfterMoveToLevel MsOccupancySensing (0x0406)   Occupancy   OccupancySensorType   PirOToUDelay   OccupancyDfltOperationMode
(15.09.2023, 13:40)admin Wrote: Here's a list of clusters and respective attributes.
Hello Team:
Where can I find this list of clusters and respective attributes, updated?
May be somethink like:
https://kb.logicmachine.net/libraries/zigbee/
best regard
Roger
Roger
This list is mostly up to date. The only major difference in the current version is addition of Phase B/C attributes to HaElectricalMeasurement.
Which clusters/attributes do you need?
