25.09.2023, 01:16
The old LM firmware is missing the zerotier.ikp file. Does anyone have its installation package? Can you share it? Thank you!
Zerotier
25.09.2023, 01:16
25.09.2023, 06:17
ZeroTier is built into firmware, so simply update yours and it will appear. This only applies to devices with newer CPU (i.MX6). Older hardware does not support ZeroTier.
25.09.2023, 08:47
The latest hardware login requires changing the administrator password, which I don't want to do. It would be even better if I could install it through the "zero tier. ipk" interface in System>packcaes
(25.09.2023, 08:47)rw_echo Wrote: The latest hardware login requires changing the administrator password, which I don't want to do. It would be even better if I could install it through the "zero tier. ipk" interface in System>packcaes Try to restore another firmware but not the later 2022 nor 2023 cause they force psw update. Try fw. 20210521, this for sure not require password changes. |
