Processing Australian BOM Weather XML Data
I'd like to pull weather data from the Australian BOM XML data feed however need some assistance in processing their (complex) XML.
The data for the Melbourne forecast can easily be downloading via the following script and I've identified the info I need (commented out in the code below). however need some help to traverse the XML using the tools available in lua.
Any help would be greatly appreciated
Kind Regards
James
require('socket.ftp')
data = socket.ftp.get('ftp://ftp.bom.gov.au/anon/gen/fwo/IDV10450.xml')
if data then
  require('lxp')
 -- retrieve data from XML node
 -- Weather_Temp_Max = tree.xpath("//forecast/area[@aac='VIC_PT042']/forecast-period[@index='1']/element[@type='air_temperature_maximum']/text()")[0]
 -- Weather_Temp_Min = tree.xpath("//forecast/area[@aac='VIC_PT042']/forecast-period[@index='1']/element[@type='air_temperature_minimum']/text()")[0]
 -- Weather_Rain = tree.xpath("//forecast/area[@aac='VIC_PT042']/forecast-period[@index='1']/text[@type='probability_of_precipitation']/text()")[0]
 grp.write('1/1/100',Weather_Temp_Max)
 grp.write('1/1/101',Weather_Temp_Min)
 grp.write('1/1/102',Weather_Rain)
log('Fetch failed to retrieve weather data')
Since Expat library is stream-oriented, xpath cannot be used. Here's an example that parses the XML and retrieves the required fields:
if not data then
  return
aac = 'VIC_PT042'
forecast = {}
function starttag(p, tag, attrs)
  if tag == 'area' and attrs.aac == aac then
    in_area = true
  elseif tag == 'forecast-period' and in_area then
    index = tonumber(attrs.index)
    if index then
      forecast[ index ] = {}
  elseif index then
    prop = attrs.type
function endtag(p, tag)
  if tag == 'area' then
    in_area = false
  elseif tag == 'forecast-period' then
    index = nil
  elseif index then
    prop = nil
function text(p, txt)
  if in_area and index and prop then
    forecast[ index ][ prop ] = txt:trim()
require('lxp').new({
  StartElement = starttag,
  EndElement = endtag,
  CharacterData = text,
}):parse(data)
Weather_Temp_Max = forecast[ 1 ].air_temperature_maximum
Weather_Temp_Min = forecast[ 1 ].air_temperature_minimum
Weather_Rain = forecast[ 1 ].probability_of_precipitation
-- remove percent sign from string
if Weather_Rain then
  Weather_Rain = Weather_Rain:gsub('%%', '')
grp.write('1/1/100', Weather_Temp_Max)
grp.write('1/1/101', Weather_Temp_Min)
grp.write('1/1/102', Weather_Rain)
Thank you so much for the solution and for the quick reply. It's working perfectly!
If you don't mind me also asking, how can I extract the start-time-local value from the same forecast-period at index 1 and convert it to a lua Date data type?
Kind Regards
James
You can get start/end time as Lua table like this. Then you can either convert it to timestamp via os.time() or use it as object value directly.
function parsedatetime(str)
  local date = {}
  date.year, date.month, date.day,
  date.hour, date.min, date.sec =
    str:match('(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)')
  return date
    in_area = true
    if index then
        start_time = parsedatetime(attrs['start-time-local']),
        end_time = parsedatetime(attrs['end-time-local']),
  elseif index then
    prop = attrs.type
-- start_time = forecast[ 1 ].start_time
-- end_time = forecast[ 1 ].end_time
Again manu thanks for the code - I've added it to our system.
We're using this info combined with local sensors to automatically open exterior blinds to keep the property cool this summer.
Kind Regards
James
Fantastic. I came searching for parsing xml thinking I would have to start from scratch but the job has already been done. Thanks!!
For future users, some of the BoM files contain forecasts for multiple locations so you can generalise by changing the start of the function to search location instead of aac
-- Product ID from FTP Public Products and wanted location within the BoM file
local bomProduct = "IDV10450"
local location = "Melbourne"
  if tag == 'area' and attrs.type == 'location' and attrs.description == location then
-- and later
data = socket.ftp.get("ftp://ftp.bom.gov.au/anon/gen/fwo/"..bomProduct..".xml")
