In my company we handle a pretty big pool of LogicMachines and we noticed that sometimes, event-based script that are active, don't trigger when they should. Here are more details about the issue:
- It can happen on LMs with any firmware (we noticed that issue on LMs with 2017 firmwares as well a LMs with 2018, 2020 and 2021 firmwares)
- Most of the time, when it happens, the LM has a pretty long uptime (it hasn't rebooted since 50 or even 100 days)
- We noticed that by placing a simple "log('hello')" at the beginning of the active event-based script, then when writing into the trigger object, the log doesn't appear in the Logs panel.
- When it happens, it doesn't happen for every KNX object of the LM, but only for some of them (which means some event-based scripts keep on triggering when they should, and some others don't).
- Since "groupmonitor.lua" is the process responsible for listening to the bus and triggering the event-based scripts, we tried killing groupmonitor.lua and then waiting for it to be reloaded (I think there is a daemon/cron job that runs every minute and launches groupmonitor.lua if it isn't running).
- After reloading groupmonitor.lua, the problem disappears and every event-based script triggers properly.
