Irrigation program
#21
Which script are you trying to disable and stop? The script above is for Scheduled script only.
(24.10.2023, 08:38)Daniel Wrote: Which script are you trying to disable and stop? The script above is for Scheduled script only.
value = event.getvalue() if value == true then   --os.sleep(3)   --grp.write("5/0/1",false) function dosleep(obj)   local timer = grp.getvalue(obj)   timer = tonumber(timer)   if timer then     if timer < mintimer then       timer = mintimer     elseif timer > maxtimer then       timer = maxtimer             end     os.sleep(timer *60 ) -- minutes -> seconds   end end mintimer = 0.1 -- minimum timer value in minutes maxtimer = 60 -- maximum timer value in minutes objects = {   {     output = '5/1/1',     timer = '5/3/1',        enable = '5/4/1',   },   {     output = '5/1/2',     timer = '5/3/2',        enable = '5/4/2',   },   {     output = '5/1/3',     timer = '5/3/3',        enable = '5/4/3',   },   {     output = '5/1/4',     timer = '5/3/4',        enable = '5/4/4',   },   {     output = '5/1/5',     timer = '5/3/5',        enable = '5/4/5',   },   {     output = '5/1/6',     timer = '5/3/6',        enable = '5/4/6',   },   {     output = '5/1/7',     timer = '5/3/7',        enable = '5/4/7',   },   {     output = '5/1/8',     timer = '5/3/8',        enable = '5/4/8',   },   {     output = '5/1/9',     timer = '5/3/9',        enable = '5/4/9',   },   {     output = '5/1/10',     timer = '5/3/10',        enable = '5/4/10',   } } for _, item in ipairs(objects) do   if grp.getvalue(item.enable) then     grp.write(item.output, true)     dosleep(item.timer)     grp.write(item.output, false)    end end grp.write("5/0/1",false) end
This is the script i'm using as event-based script.
Set event script "Execution mode" to "Last instance only".
(24.10.2023, 08:50)admin Wrote: Set event script "Execution mode" to "Last instance only".
How can I configure this?
In event script settings. You need 2023 or newer firmware for this.
Ok so I'll have an event-based script for the irrigation program configured as last instance only execution mode.
And then I also need an event-based script in normal execution mode like the shown below in order to stop the irrigation program. Is that correct? Thank you!
value = event.getvalue() if value == false then name = 'my script name' item = script.get(name) script.disable(name) os.execute('pkill -f "scripting-scheduled.lua ' .. item.id .. '"')
You don't need an extra script for this. In "Last instance only" mode all previous script instances are stopped once new value arrives.
Your script should be modified to turn off all outputs when false is received. This is needed because when the script is running it's mostly sleeping with one output turned on.
value = event.getvalue() function dosleep(obj)   local timer = grp.getvalue(obj)   timer = tonumber(timer)   if timer then     if timer < mintimer then       timer = mintimer     elseif timer > maxtimer then       timer = maxtimer     end     os.sleep(timer * 60) -- minutes -> seconds   end end mintimer = 0.1 -- minimum timer value in minutes maxtimer = 60 -- maximum timer value in minutes objects = {   {     output = '5/1/1',     timer = '5/3/1',     enable = '5/4/1',   },   {     output = '5/1/2',     timer = '5/3/2',     enable = '5/4/2',   },   {     output = '5/1/3',     timer = '5/3/3',     enable = '5/4/3',   },   {     output = '5/1/4',     timer = '5/3/4',     enable = '5/4/4',   },   {     output = '5/1/5',     timer = '5/3/5',     enable = '5/4/5',   },   {     output = '5/1/6',     timer = '5/3/6',     enable = '5/4/6',   },   {     output = '5/1/7',     timer = '5/3/7',     enable = '5/4/7',   },   {     output = '5/1/8',     timer = '5/3/8',     enable = '5/4/8',   },   {     output = '5/1/9',     timer = '5/3/9',     enable = '5/4/9',   },   {     output = '5/1/10',     timer = '5/3/10',     enable = '5/4/10',   } } for _, item in ipairs(objects) do   if value == true then     if grp.getvalue(item.enable) then       grp.write(item.output, true)       dosleep(item.timer)       grp.write(item.output, false)     end   else     grp.checkwrite(item.output, false)   end end
