Connection from different NET
Greetings
I would need to be able to access the LM from different subnets:
192.168.1.n
192.168.2.n
I tried to change the subnet to 255.255.252.0 but to no avail, is there something in the LM that blocks access from different networks?
See this: https://forum.logicmachine.net/showthrea...2#pid16682
(21.11.2023, 08:06)Frank68 Wrote: Greetings
192.168.1.n
192.168.2.n
Best regards
forsterm
(21.11.2023, 08:11)forsterm Wrote: See this: https://forum.logicmachine.net/showthrea...2#pid16682
192.168.1.n
192.168.2.n
I not ned more LM on the net i need more computer from different net able to connect to the same LM, i have the vlan but is all open.
This has to be configured on your router. Make sure that LM has a correct gateway set. Keep netmask as 255.255.255.0.
(21.11.2023, 13:39)admin Wrote: This has to be configured on your router. Make sure that LM has a correct gateway set. Keep netmask as 255.255.255.0.
Hi, I have the corret SN and GW , but nothing, is not possible to reach the LM from different network, if I set more I,
IN the LM I use Zerotier for remote connection and if i set more IP ZeroTier not work.
how can I solve it ?
Thank's
Having an extra IP address should not affect ZeroTier unless you have the same network on both eth0 and virtual ZeroTier interface.
If you have several subnets on the same LAN then you should be able to connect to LM using both IP addresses. Of course, the connecting device should also belong to the same subnet.
If subnets are not different LANs then your router must be configured to accept and route traffic between these subnets. In this case LM does not need an extra IP address.
