REACTOR LTE band aggregation
HI
Is it possible in the LTE reactor to aggregate the ETH and LTE bands to exploit the maximum possible speed?
A thousand thanks
It's not supported. What is the actual use case for higher speed?
(30.11.2023, 09:33)admin Wrote: It's not supported. What is the actual use case for higher speed?
mixed that where I have the reactor I don't have a good LTE signal and I have the network to be able to use both, I use the SIM for SMS.
I have to leave the GW otherwise they won't be able to connect to the internal network, while according to the instructions I should remove it to use the SIM.
how can I solve it?
Thank you
If you only need SMS you can disable 3G/4G connection in System config and add this code to Init script:
io.writefile('/sys/class/gpio/export', 8) io.writefile('/sys/class/gpio/export', 71) io.writefile('/sys/class/gpio/gpio8/direction', 'high') os.sleep(1) io.writefile('/sys/class/gpio/gpio8/direction', 'low') io.writefile('/sys/class/gpio/gpio71/direction', 'high')
(30.11.2023, 09:46)admin Wrote: If you only need SMS you can disable 3G/4G connection in System config and add this code to Init script:
does the script for sending sms remain identical?
Nothing else must be changed. This init script will simply power up the internal modem.
(30.11.2023, 09:53)admin Wrote: Nothing else must be changed. This init script will simply power up the internal modem.
I add code, in init script, run the init script but qhen i test SMS sending nothing.
Why?
Restart SMS resident script or reboot LM.
