A litle script, but I got no output
I have made this script:
But when I send a 1 value at this two objectadress, nothing happen. What do I do wrong?
Input_1 = event.getvalue('0/2/3')
Input_2 = event.getvalue('0/2/9')
Output = '0/2/0'
if input_1 == 1
  and input_2 == 1 then
grp.write(output, 35)
use == true instead of == 1 at your if-statement.
Best regards
forsterm
I tried that, but it didn't help
Output = '0/2/0'
if input_1 == true
  and input_2 == true then
And check for case sensitive Input_ =…  -> if input_1 instead of if Input_1 … and Output =.. -> grp.write(output, .. instead of grp.write(Outpu..
I recommend to only use lower case to avoid those kind of mistakes..
Didn't help
input_1 = event.getvalue('0/2/3')
input_2 = event.getvalue('0/2/9')
output = '0/2/0'
if input_1 == true
Sorry missed that one, event.getvalue needs to be grp.getvalue
Also try to log your vars like log(input_1, input_2) so you know their values that you need to use in your conditions…
Hi Quattro,
You have created an event on the scene object. So the script start every time this object change. I suggest you to create a script on tag and assign to input 1and 2 this tag.
So every time that those objects change the script starts.
Pay attention at the variables name must be the same.
Best regards Cristian
Hi, tanks alot. I got it to work.
I now used grp.getvalue, change that the script react at a tag, and put the same tag on both adress object
