mail with port 25 (old style)
 how can I set this script to send a e-mail without SSL3 ?
function mail(to, subject, message)
    local settings = {
    from = 'mailsender@server.com',
    -- smtp username
    user = 'Myuser',
    -- smtp password --> no password
    --password = '',
    -- smtp server
    server = 'inside.server.com',
    -- smtp server port
    port = 25,
    --secure = 'sslv23',
Alberto
KNX Advanced Partner + Tutor
It should work, log what the server reply/error is:
res, err = mail('user@example.com', 'test subject', ' test message')
log(res, err)
oneshot test 18.01.2024 12:15:43
* arg: 1
* string: Could not send email:
* arg: 2
* string: 550 Requested action not taken: mailbox unavailable
* arg: 3
* string:
* arg: 1
* nil
* arg: 2
* nil
Are you sending a test message to a real email address or the example one from my previous post?
The communication is working fine. Sending does not complete either because of incorrect configuration in mail settings or something is wrong on the SMTP server side.
I'm using a real e-mail address.
I'll check it with the IT, thanks
