Zigbee gateway integration
(14.12.2023, 14:52)admin Wrote: This valve is not supported at the moment. As an alternative solution the next app version will have Bosch Radiator Thermostat II support.
(15.12.2023, 08:11)admin Wrote: It does support remote temperature sensor but we haven't tested it yet. The only limitation is that Bosch valve does not have any timeout mechanism for the remote temperature. Other valves will revert back to the internal temperature sensor if the remote value has not been received for some time. For Bosch valve to revert you need to power it down by removing the batteries.
are there any other good options exept bosch valve that is supported?
Not really. There's an alternative which uses WiFi and integrates via MQTT, but we haven't tested it ourselves: https://www.shelly.com/en-gb/products/pr...shelly-trv
I have a CTM mTouch OP thermostat that I am trying to get paired with LM. I find it, but can only switch it on and off. Is this a profile you can add? They also have a bunch of other products using DATEK zigbee chip. https://ctmlyng.no/op/
Only basic features can be supported - local thermostat temperature and setpoint control. All other features are implemented in a non-standard way.
What does that mean in regards to function? You can read actual temp, and control setpoint?
Thermostat will report its internal temperature and setpoint can be controlled.
Is there a list of supported devices? So that i can choose t right one ?
https://kb.logicmachine.net/misc/zigbee-devices/
Is ther any Chance to integrate the new IKEA Vinstryka Air Quality Sensor ?
https://github.com/Koenkk/zigbee2mqtt/issues/16717
This would be a huge improvement.
VINDSTYRKA can be added but it will take some time as we need to buy the sensor first Smile
Will SONOFF ZBMINI be supported? I see ZBMINIL2 in the list but not that one.
https://sonoff.tech/product/diy-smart-switches/zbmini/
Here is the Device info for Vindstyrka, got mine yesterday. I hope this helps you a little bit.
123456789101112131415161718192021222324252627282930
Manufacturer: IKEA of Sweden Model: VINDSTYRKA Firmware version: 1.0.010 Device type: Router Power source: Mains Receive when idle: Yes Endpoint 1 Profile: 260 Input clusters - Basic (0) - Identify (3) - Groups (4) - MsTemperatureMeasurement (1026) - MsRelativeHumidity (1029) - 64599 - 64636 - 1066 - 64638 Output clusters - Identify (3) - Ota (25) - PollCtrl (32) - HvacFanCtrl (514) Endpoint 242 Profile: 41440 Output clusters - GreenPower (33)
Hello team:
Is it possible to Add profiles for this two Devices, On and Off work fine, but it is not possible to adjust colors or or temperature color.
It is one fisical device, but it show two zigbee devices
https://www.dresden-elektronik.com/produ...llast.html
Device 1: ----------------------------------------------------------------------
dresden elektronik - FLS-PP3 White - device information
Manufacturer: dresden elektronik
Model: FLS-PP3 White
Firmware version: 0214.201000F5
Device type: Router
Power source: Mains
Endpoint 10
Profile: 49246
Input clusters
- Basic (0)
- LightLink (4096)
- Groups (4)
- Identify (3)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- LightingColorCtrl (768)
- 64718
Output clusters
- Ota (25)
Endpoint 11
Profile: 49246
Input clusters
- Basic (0)
- LightLink (4096)
- Groups (4)
- Identify (3)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
Reported attributes
- level: 100
- onoff: false
Device 2: ----------------------------------------------------------------------
Firmware version: 0214.201000EB
Device type: Router
Power source: Mains
Endpoint 10
Profile: 49246
Input clusters
- Basic (0)
- LightLink (4096)
- Groups (4)
- Identify (3)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- 64718
Output clusters
- Ota (25)
Endpoint 11
Profile: 49246
Input clusters
- Basic (0)
- LightLink (4096)
- Groups (4)
- Identify (3)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
Reported attributes
- level: 1
- onoff: false
Ref the attached picture. My zigbee app looks like this all of the sudden. Using USB dongle an latest firmware and app..
Any ideas what could cause this? have tried resetting LM and Dongle,.
Power down LM and check again.
(19.01.2024, 08:30)Daniel Wrote: Power down LM and check again.
I did reboot LM, still same.
Did you do reboot via web interface or a complete power cycle? How many devices do you have paired?
just a reboot from webIF, i only have 3 devices. I will try a powercycle later today.
Do a full power cycle as Daniel suggested.
(19.01.2024, 10:05)admin Wrote: Do a full power cycle as Daniel suggested.
will do.
