1bit to 1byte rely on which pushbutton.
Hi.
I need to do a script that contains 5 GA 1bit object (push-buttons) and one 1byte value object
Function:
When I push the first button it sends 'true' on the first GA and then need to be convert to a GA object value that shows 100%
Then I push the second button and it sends 'true' to the second GA and then need to change the same object value 75% instead of 100%
And so on with the other three pushbuttons..
Create event script on each bit object with such script and change the values.
value = event.getvalue()
if value then
grp.checkwrite('1/1/1', 100)
Thanks, It is as simple as that!
