Threads: 15
Hi all,
I'm working on a
Vestaboard API integration. And so far everything is working fine but now i want to replace the status (layout) to a readable string so i can use it in my visualization.
The Vestaboard returns the layout like this:
"currentMessage" : {
"layout" :
"[[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,8,5,12,12,15,0,23,15,18,12,4,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]]" ,
"id" :
"172c7808-52db-4eb9-9ecf-505bd00436bc"
And i created a JSON string of all numbers and their corresponding characters:
characters =
'{"0":" ","1":"a","2":"b","3":"c","4":"d","5":"e","6":"f","7":"g","8":"h","9":"i","10":"j","11":"k","12":"l","13":"m","14":"n","15":"o","16":"p","17":"q","18":"r","19":"s","20":"t","21":"u","22":"v","23":"w","24":"x","25":"y","26":"z","27":"1","28":"2","29":"3","30":"4","31":"5","32":"6","33":"7","34":"8","35":"9","36":"0","37":"!","38":"@","39":"#","40":"$","41":"(","42":")","44":"-","46":"+","47":"&","48":"=","49":";","50":":","52":"\'","53":"\\"","54":"%","55":",","56":".","59":"/","60":"?","62":"°","63":"red","64":"orange","65":"yellow","66":"green","67":"blue","68":"purple","69":"white","70":"black","71":""}' So now i need a script that convert the Vestaboard "layout" with the characters string.
Many thanks for your help.
Threads: 43
Try this. The example has the layout array encoded as a JSON string for some reason. It might be an error in the documentation. If it's not then uncomment line 42 and remove line 43.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
chars = {
0 ] =
1 ] =
"A" , [
2 ] =
"B" , [
3 ] =
"C" , [
4 ] =
"D" , [
5 ] =
"E" ,
6 ] =
"F" , [
7 ] =
"G" , [
8 ] =
"H" , [
9 ] =
"I" , [
10 ] =
"J" , [
11 ] =
"K" ,
12 ] =
"L" , [
13 ] =
"M" , [
14 ] =
"N" , [
15 ] =
"O" , [
16 ] =
"P" ,
17 ] =
"Q" , [
18 ] =
"R" , [
19 ] =
"S" , [
20 ] =
"T" , [
21 ] =
"U" ,
22 ] =
"V" , [
23 ] =
"W" , [
24 ] =
"X" , [
25 ] =
"Y" , [
26 ] =
"Z" ,
27 ] =
"1" , [
28 ] =
"2" , [
29 ] =
"3" , [
30 ] =
"4" , [
31 ] =
"5" ,
32 ] =
"6" , [
33 ] =
"7" , [
34 ] =
"8" , [
35 ] =
"9" , [
36 ] =
"0" ,
37 ] =
38 ] =
39 ] =
40 ] =
41 ] =
42 ] =
44 ] =
46 ] =
47 ] =
48 ] =
49 ] =
50 ] =
52 ] =
53 ] =
54 ] =
55 ] =
56 ] =
59 ] =
60 ] =
62 ] =
function decode (
input )
for i ,
code in ipairs (
input )
do
input [
i ] =
chars [
code ]
or ''
local res =
table.concat (
input )
return res :
trim ()
data =
"currentMessage": {
"layout": [
"id": "172c7808-52db-4eb9-9ecf-505bd00436bc"
data =
json.pdecode (
data )
messages =
data.currentMessage.layout
for i ,
message in ipairs (
messages )
do
messages [
i ] =
decode (
message )
log (
messages )
Threads: 15
Thanks for your help admin. Below the complete script to get the Vestaboard message including the colors regarding their
character codes
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
require (
'json' )
require (
'ltn12' )
require (
'socket.http' )
token =
'YOUR TOKEN'
chars = {
0 ] =
1 ] =
"A" , [
2 ] =
"B" , [
3 ] =
"C" , [
4 ] =
"D" , [
5 ] =
"E" ,
6 ] =
"F" , [
7 ] =
"G" , [
8 ] =
"H" , [
9 ] =
"I" , [
10 ] =
"J" , [
11 ] =
"K" ,
12 ] =
"L" , [
13 ] =
"M" , [
14 ] =
"N" , [
15 ] =
"O" , [
16 ] =
"P" ,
17 ] =
"Q" , [
18 ] =
"R" , [
19 ] =
"S" , [
20 ] =
"T" , [
21 ] =
"U" ,
22 ] =
"V" , [
23 ] =
"W" , [
24 ] =
"X" , [
25 ] =
"Y" , [
26 ] =
"Z" ,
27 ] =
"1" , [
28 ] =
"2" , [
29 ] =
"3" , [
30 ] =
"4" , [
31 ] =
"5" ,
32 ] =
"6" , [
33 ] =
"7" , [
34 ] =
"8" , [
35 ] =
"9" , [
36 ] =
"0" ,
37 ] =
38 ] =
39 ] =
40 ] =
41 ] =
42 ] =
44 ] =
46 ] =
47 ] =
48 ] =
49 ] =
50 ] =
52 ] =
53 ] =
54 ] =
55 ] =
56 ] =
59 ] =
60 ] =
62 ] =
63 ] =
"[R]" , [
64 ] =
"[O]" , [
65 ] =
"[Y]" , [
66 ] =
"[G]" ,[
67 ] =
"[B]" ,
68 ] =
"[V]" , [
69 ] =
"[W]" , [
70 ] =
71 ] =
function decode (
input )
for i ,
code in ipairs (
input )
do
input [
i ] =
chars [
code ]
or ''
local res =
table.concat (
input )
return res :
trim ()
data = {}
res ,
code =
socket.http.request ({
url =
'https://rw.vestaboard.com/' ,
method =
'GET' ,
headers = {
'X-Vestaboard-Read-Write-Key' ] =
token ,
'Content-Type' ] =
'application/json' ,
sink =
ltn12.sink.table (
data ),
if res and code ==
200 then
data =
table.concat (
data )
data =
json.pdecode (
data )
messages =
json.pdecode (
data.currentMessage.layout )
log (
'Vestaboard error' ,
code ,
table.concat (
data ))
for i ,
message in ipairs (
messages )
do
messages [
i ] =
decode (
message )
log (
messages )
