SOMETHING STRANGE
Greetings
a strange thing is happening to me, I'm connected remotely to an LM5 via Zerotier, I get to the web page but ETS doesn't see any device on the TP line, I updated the LM firmware this morning with version 2024, what could it depend on?
Thank you very much
Did you select, allow global IPs?
(28.03.2024, 12:34)Daniel Wrote: Did you select, allow global IPs?
WHERE ?
https://kb.logicmachine.net/misc/zerotier/
13
(28.03.2024, 12:41)Daniel Wrote: https://kb.logicmachine.net/misc/zerotier/
13
HI
I set everything as on the other systems but there is something strange.
via zerotier I connect to the LM without problems LM tells me TP bus OK, I do a line scan I see activity increase on LM but then ETS5 doesn't find any devices.
All I have to do is try to go to the system, is port 3671 the only one used by ETS for programming?
Thank you
I just tested zerotier on 2024 fw and it works fine, was able to do a download, scan, ping, reset. The only thing which doesn't work is Device info read. For tunneling this port is used, did you select NAT?
