Wiser for KNX malfunction
I have here a Wiser for KNX from a customer that may have a problem.
I can ping the default IP address but the webserver doesn't answer to anything. It is like the webserver app has stopped.
I have tried factory reset several times but the issue still persists.
Any idea how could I recover this  Huh ?
Thank you
https://download.schneider-electric.com/...rd_W4K.zip
I tried that, but now even the Outside and LAN LEDs does not light on, only the inside led is flashing.
Now I can't even ping the W4K. I don't now what is happening.
The firmware is copied correctly to the SD card and I have tried other sd card (16GB) but the problem continues.
Are you sure you used correct firmware?
Use our recovery image, the SE is outdated.
https://kb.logicmachine.net/misc/reflash...ng-player/
(15.04.2024, 15:04)Daniel Wrote: Are you sure you used correct firmware?
I used the firmware that comes with Schneider Application Note from Erwin van der Zwart.
I also tried another firmware from schneider website (ex 2.7.0) but with no success.
Can I flash with LM firmware for testing ?
Use SE firmware but our recovery image.
(15.04.2024, 16:03)Daniel Wrote: Use SE firmware but our recovery image.
Thanks a lot, LM image fixed this issue Heart
