Email synax: messeage depending on the value of a group value
Sending emails with my W4K is working. Once a day, I'd like to send an email. The message should depend on the vealue of the group values. This message should be list, of all values, which are below a certain limit - in this case 85. I tried the following code - synax error. Any idea?
for i = 0, 30, 1 do   SP = grp.getvalue('35/1/' ..i)   if (SP < 85) then     message = 'Alert: ' '35/1/' ..i '<br>' end end
(17.04.2024, 21:36)cgn Wrote: Sending emails with my W4K is working. Once a day, I'd like to send an email. The message should depend on the vealue of the group values. This message should be list, of all values, which are below a certain limit - in this case 85. I tried the following code - synax error. Any idea?
...missing string concat after Alert: string...
for i = 0, 30, 1 do   SP = grp.getvalue('35/1/' .. i)   if (SP < 85) then     message = 'Alert: ' .. '35/1/' .. i '<br>'   end end
'35/1/' ..i '<br>' Must be '35/1/' .. i .. '<br>'
Corrected version that will alert all objects that are below the threshold instead of only one:
message = '' for i = 0, 30 do   addr = '35/1/' .. i   value = grp.getvalue(addr)      if value < 85 then     message = message .. 'Alert: ' .. addr .. ' = ' .. value .. '<br>\n'   end end if message == '' then   message = 'OK' end
