gsm signal
HI
I followed the instructions I found in the forum on how to evaluate the modem signal, I modified the user and sms (resident) scripts as recommended, now how can I read the global variable quality to be able to represent it in visual display?
is it stored in storage?
A thousand thanks
Add grp.update like in this script (line #119): https://forum.logicmachine.net/showthrea...4#pid31874
(18.04.2024, 09:33)admin Wrote: Add grp.update like in this script (line #119): https://forum.logicmachine.net/showthrea...4#pid31874
This is my script code
I have try to log the varibale quality but log nothing ???
-- init if not numbers then   require('user.sms')   require('json')   require('socket')   -- allowed numbers, SMS from other numbers will be ignored   numbers = { '3332958126' }   -- port number depends on modem model   comport = 'ttyUSB2'   doreset = false -- set to true if USB reset is required before starting any communication   -- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN   -- pincode = '0000'   -- command parser   parser = function(cmd, sender)     local find, pos, name, mode, offset, value, dvalue, obj, message     cmd = cmd:trim()     mode = cmd:sub(1, 1):upper()     -- invalid request     if mode ~= 'W' and mode ~= 'R' then       return     end     cmd = cmd:sub(3):trim()     -- parse object name/address     find = cmd:sub(1, 1) == '"' and '"' or ' '     offset = find == '"' and 1 or 0     -- pad with space when in read mode     if mode == 'R' and find == ' ' then       cmd = cmd .. ' '     end     -- find object name     pos = cmd:find(find, 1 + offset, true)     -- name end not found, stop     if not pos then       return     end     -- get name part     name = cmd:sub(1 + offset, pos - offset):trim()     if mode == 'W' then       value = cmd:sub(pos + offset):trim()       if #value > 0 then         -- try decoding value         dvalue = json.pdecode(value)         if dvalue ~= nil then           value = dvalue         end         -- send to bus         grp.write(name, value)       end     -- read request     else       obj = grp.find(name)       -- object not known       if not obj then         return       end       -- send read request and wait for an update       obj:read()       os.sleep(1)       -- read new value       value = grp.getvalue(name)       -- got no value       if value == nil then         return       end       -- add object name if specified       if obj.name then         name = string.format('%s (%s)', obj.name, obj.address)       end       message = string.format('Value of %s is %s', name, json.encode(value))       modem:sendsms('+' .. sender, message)     end   end   -- incoming sms handler     readcsq = function()     local res, err, reply = modem:send('AT+CSQ')     local rssi     if reply then       rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')     end     rssi = tonumber(rssi) or 0     if 2 <= rssi and rssi <= 9 then       quality = 'marginal'     elseif 10 <= rssi and rssi <= 14 then       quality = 'ok'     elseif 15 <= rssi and rssi <= 19 then       quality = 'good'     elseif 20 <= rssi and rssi <= 30 then       quality = 'excellent'     else       quality = 'unknown'     end     grp.write('32/0/0', quality)  -- Modem signal level write to group   end   csqtime = os.time()   handler = function(sms)     --alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))     -- sms from known number, call parser     if table.contains(numbers, sms.sender) then       --parser(sms.data, sms.sender)     end   end     now = os.time()     delta = math.abs(now - csqtime)     if delta >= 15 then       csqtime = now       readcsq()     end     -- check local udp server for messages to send   udphandler = function(server)     -- check for local sms to send     local msg = server:receive()     -- got no message     if not msg then       return     end     -- split into number and message     local sep = msg:find(' ')     if not sep then       return     end     --alert('sending sms: ' .. msg)     modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))   end end -- handle data from modem if modem then   if modem:run() then     udphandler(server)   else     --alert('SMS handler lost connection')     modem:reinit()   end -- modem init else   --alert('SMS handler init')   -- open serial port   modem = AT:init('/dev/' .. comport, doreset)   -- init ok   if modem then     -- set sms handler     modem:setsmshandler(handler)     -- send pin if set     if pincode then       modem:send('AT+CPIN=' .. pincode)       modem:read()     end     -- set to pdu mode     modem:send('AT+CMGF=0')     -- enable sms notifications     modem:send('AT+CNMI=1,1,0,0,0')     -- fixup encoding     modem:send('AT+CSCS="GSM"')     -- delete all saved messages     modem:send('AT+CMGD=1,4')     -- local udp server for sending sms     server = socket.udp()     server:setsockname('127.0.0.1', 12535)     server:settimeout(0.1)     --alert('SMS handler started')   -- init failed   else     --alert('SMS USB init failed')   end end
Try this:
-- init if not numbers then   require('user.sms')   require('json')   require('socket')   -- allowed numbers, SMS from other numbers will be ignored   numbers = { '3332958126' }   -- port number depends on modem model   comport = 'ttyUSB2'   doreset = false -- set to true if USB reset is required before starting any communication   -- if SIM PIN is enabled, uncomment the line below and replace 0000 with SIM PIN   -- pincode = '0000'   -- command parser   parser = function(cmd, sender)     local find, pos, name, mode, offset, value, dvalue, obj, message     cmd = cmd:trim()     mode = cmd:sub(1, 1):upper()     -- invalid request     if mode ~= 'W' and mode ~= 'R' then       return     end     cmd = cmd:sub(3):trim()     -- parse object name/address     find = cmd:sub(1, 1) == '"' and '"' or ' '     offset = find == '"' and 1 or 0     -- pad with space when in read mode     if mode == 'R' and find == ' ' then       cmd = cmd .. ' '     end     -- find object name     pos = cmd:find(find, 1 + offset, true)     -- name end not found, stop     if not pos then       return     end     -- get name part     name = cmd:sub(1 + offset, pos - offset):trim()     if mode == 'W' then       value = cmd:sub(pos + offset):trim()       if #value > 0 then         -- try decoding value         dvalue = json.pdecode(value)         if dvalue ~= nil then           value = dvalue         end         -- send to bus         grp.write(name, value)       end     -- read request     else       obj = grp.find(name)       -- object not known       if not obj then         return       end       -- send read request and wait for an update       obj:read()       os.sleep(1)       -- read new value       value = grp.getvalue(name)       -- got no value       if value == nil then         return       end       -- add object name if specified       if obj.name then         name = string.format('%s (%s)', obj.name, obj.address)       end       message = string.format('Value of %s is %s', name, json.encode(value))       modem:sendsms('+' .. sender, message)     end   end   -- incoming sms handler     readcsq = function()     local res, err, reply = modem:send('AT+CSQ')     local rssi     if reply then       rssi = reply:match('%+CSQ:%s+(%d+),(%d+)')     end     rssi = tonumber(rssi) or 0     if 2 <= rssi and rssi <= 9 then       quality = 'marginal'     elseif 10 <= rssi and rssi <= 14 then       quality = 'ok'     elseif 15 <= rssi and rssi <= 19 then       quality = 'good'     elseif 20 <= rssi and rssi <= 30 then       quality = 'excellent'     else       quality = 'unknown'     end     grp.write('32/0/0', quality)  -- Modem signal level write to group   end   csqtime = os.time()   handler = function(sms)     --alert('incoming sms: [%s] %s', tostring(sms.sender), tostring(sms.data))     -- sms from known number, call parser     if table.contains(numbers, sms.sender) then       --parser(sms.data, sms.sender)     end   end   -- check local udp server for messages to send   udphandler = function(server)     -- check for local sms to send     local msg = server:receive()     -- got no message     if not msg then       return     end     -- split into number and message     local sep = msg:find(' ')     if not sep then       return     end     --alert('sending sms: ' .. msg)     modem:sendsms(msg:sub(1, sep - 1), msg:sub(sep + 1))   end end -- handle data from modem if modem then   if modem:run() then     udphandler(server)     now = os.time()     delta = math.abs(now - csqtime)     if delta >= 15 then       csqtime = now       readcsq()     end   else     --alert('SMS handler lost connection')     modem:reinit()   end -- modem init else   --alert('SMS handler init')   -- open serial port   modem = AT:init('/dev/' .. comport, doreset)   -- init ok   if modem then     -- set sms handler     modem:setsmshandler(handler)     -- send pin if set     if pincode then       modem:send('AT+CPIN=' .. pincode)       modem:read()     end     -- set to pdu mode     modem:send('AT+CMGF=0')     -- enable sms notifications     modem:send('AT+CNMI=1,1,0,0,0')     -- fixup encoding     modem:send('AT+CSCS="GSM"')     -- delete all saved messages     modem:send('AT+CMGD=1,4')     -- local udp server for sending sms     server = socket.udp()     server:setsockname('127.0.0.1', 12535)     server:settimeout(0.1)     --alert('SMS handler started')   -- init failed   else     --alert('SMS USB init failed')   end end
nothing return nil from rssi
but not possible message sms work fine
Log the raw reply (around line 97):
local res, err, reply = modem:send('AT+CSQ') log(res, err, reply)
(18.04.2024, 11:11)admin Wrote: Log the raw reply (around line 97):
Yes found problem in this line
as always thank you very much
