Hi all,
I writed this script to open a plan according to a user, and hiding menus if it is not an 'admin' one.
It works fine on a HW2 v2.8.0
It don't works on a SpaceLynk v2.8.3
So, it seams I have to install "user.lp" on the user directory on my SpaceLynk.
As I can't acces viai FTP (security reason) to the SpaceLynk's customer, I want to try to create it via a Lua scritp as this :
Question 1 : what is exactly the path ? "user/user.lp" for example.
Question 2 : Is it necessary to update access rights for user.lp to rw-rw-rw- ?
Thank's in advance !
123456789101112131415161718192021222324252627282930313233343536373839404142
// Dominique Barboyon (c) 19/03/2024
// opens a specific plan according to the user login and hides menus if it's not admin
// 19/03/2024 - v1.0
$(function(){
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (xhttp.readyState == 4 && xhttp.status == 200) {
var res = xhttp.responseText;
res = res.trim();
var isuser = 0;
if (typeof(res) !== "undefined" && res !== null){
if (res == 'lota00'){
showPlan(3);
isuser = 1;
if (res == 'lotb05'){
showPlan(19);
isuser = 1;
if (res == 'admin_craft'){
showPlan(21);
isuser = 0;
if (res == 'admin'){
showPlan(21);
isuser = 0;
if (isuser == 1){
$('.menu').hide();
$('.layers').css('left', 0);
xhttp.open("GET", "/user/user.lp", true);
xhttp.send();
});So, it seams I have to install "user.lp" on the user directory on my SpaceLynk.
local f = assert(io.open("user/user.lp", "w"))
f:write("<?", '\n')
f:write("require('apps')", '\n')
f:write("clientuser = request.username or 'anonymous'", '\n')
f:write("print(clientuser)", '\n')
f:write("?>", '\n')
f:close()Question 1 : what is exactly the path ? "user/user.lp" for example.
