30.04.2024, 11:22
		LM 2024.04 release firmware is ready (previously marked as RC3).
Changes from 2024.02 RC2
- Fixed grp.create() not working unless json library was loaded beforehand
- Fixed ZeroTier config error when network connection type is set to DHCP
- Empty Custom values ({} or [] in JSON format) are now treated as no Custom values
- If Custom values are used in the Schedulers user UI, the first value is now selected when creating new events
Known issues
- Homekit application must be updated to the latest version via LM app store after the firmware upgrade.
New LM Home application
More info here: https://forum.logicmachine.net/showthread.php?tid=5220
You can find the hardware model in the "Upgrade firmware" window:
![[Image: attachment.php?aid=1740]](https://forum.logicmachine.net/attachment.php?aid=1740)
LM5 Power devices with i.MX6 CPU
LM5 Lite (3 DIN units): image file | signature
LM5 Lite + Ext (4 or 6 DIN units): image file | signature
LM5 Reactor GM KNX: image file | signature
LM5 Reactor GM CANx: image file | signature
LM5 Reactor Dimmer KNX: image file | signature
LM5 Reactor Dimmer CANx: image file | signature
LM5 Reactor IO V2/V3: image file | signature
LM5 Reactor IO V2/V3 + LTE: image file | signature
LM5 M4 (4 DIN units): image file | signature
LM Wall (Ambient V2): image file | signature
Extra packages (i.MX6 CPU)
libmysqlclient has been replaced by libmariadb. No script changes are needed for MySQL/MariaDB connectivity.
Devices with old CPU (i.MX28)
LM2 IMX: image file | signature
LM3 V1 (4 x RS-485): image file | signature
LM3 V2 (3 x RS-485 and 1 x RS-242): image file | signature
LM4: image file | signature
LM5 4 DIN units: image file | signature
LM Wall (Ambient): image file | signature
LM Reactor Lite: image file | signature
LM Reactor V1: image file | signature
LM Reactor V2: image file | signature
LM Reactor V3: image file | signature
Extra packages (i.MX28 CPU)
KNX Data Secure
Video tutorial: https://forum.logicmachine.net/showthrea...15#pid3391
Known issues
KNX Data Secure
