[OLD CPU ONLY] LogicMachine firmware 2024.04
LM 2024.04 release firmware is ready (previously marked as RC3).
Changes from 2024.02 RC2
- Fixed grp.create() not working unless json library was loaded beforehand
- Fixed ZeroTier config error when network connection type is set to DHCP
- Empty Custom values ({} or [] in JSON format) are now treated as no Custom values
- If Custom values are used in the Schedulers user UI, the first value is now selected when creating new events
Known issues
- Homekit application must be updated to the latest version via LM app store after the firmware upgrade.
New LM Home application
More info here: https://forum.logicmachine.net/showthread.php?tid=5220
You can find the hardware model in the "Upgrade firmware" window:
[Image: attachment.php?aid=1740]
LM5 Power devices with i.MX6 CPU
2025.12 firmware
Devices with old CPU (i.MX28)
LM2 IMX: image file | signature
LM3 V1 (4 x RS-485): image file | signature
LM3 V2 (3 x RS-485 and 1 x RS-242): image file | signature
LM4: image file | signature
LM5 Lite (3 DIN units): image file | signature
LM5 Lite + Ext (4 or 6 DIN units): image file | signature
LM5 4 DIN units: image file | signature
LM Wall (Ambient): image file | signature
LM Reactor Lite: image file | signature
LM Reactor V1: image file | signature
LM Reactor V2: image file | signature
LM Reactor V3: image file | signature
Extra packages (i.MX28 CPU)
libmysqlclient has been replaced by libmariadb. No script changes are needed for MySQL/MariaDB connectivity.
KNX Data Secure
Video tutorial: https://forum.logicmachine.net/showthrea...15#pid3391
Dear all,
  I currently have an LM5 Rio set that needs to be reinstalled with the memory card. However, after installing the new card, the LM5 cannot boot up (only one power light is on - the main light flashes red continuously).
  Hope to receive support to find the cause and how to handle it.
  Please help me this case!
  Thank so much!
Seems like you used wrong recovery image. Which one did you select?
You should use imx28 recovery image and LM5 Lite + Ext (4 or 6 DIN units) firmware.
I used i.mx28 and it's still the same.
It dont started IP Web.
Did you use the correct firmware as I mentioned above?
I made sure I downloaded the correct i.MX28,
however after installing the memory card into the LM5, it cannot boot to IP 192.168.0.10
Clera browser cache or try different.
Have you configured PC network interface so it is on 192.168.0.0/24 network?
Hallo zusammen,
Ich brauche deine Unterstützung.
Nach einem erfolgreichen Update habe ich Probleme mit dem Zugriff über eine ISE Remote, ähnlich wie beim Gira S1. Bisher habe ich eine direkte Verbindung über die ISE Cloud zu LM, wo ich mich mit meinem Benutzer von LM aus anmelden konnte. Jetzt wird das Passwort einfach ignoriert. Der Zugriff über VPN funktioniert einwandfrei. Ich kenne aber mehrere Kunden, die einen solchen Zugang nutzen. Leider kann ich die kostenlose Visualisierung über LM Cloud nicht nutzen und aus diesem Grund sollte der Zugriff über ISE Remote funktionieren.
Hat sich in puncto Sicherheit in der neuen Firmware etwas geändert? Kann ich es deaktivieren oder umgehen?
@Burghardt Systems, please write in English. Can you provide remote access both via ISE and ZeroTier to LM so we can check what's wrong?
Hi @Daniel, I have updated the LM5 Lite firmware of a client of mine and I have lost the connection to the OpenVPN.
The LM is working correctly and I can access Mosaic via remote.logicmachine and everything seems to work fine, but the OpenVPN has stopped working.
Do you know if there is any problem with this new firmware version and openVPN.
Check this: https://forum.logicmachine.net/showthrea...0#pid34590
For OpenVPN connections I am using Mikrotik.
I have all LogicMachine connected by ovpn to my mikrotik.
I have upgraded it, but it has not resolved.
Any more hints on how I can resolve it,
Try upgrading RouterOS to the latest version. You can also try Wireguard instead of OpenVPN. You need RouterOS 7 for this.
(29.05.2024, 14:36)admin Wrote: Try upgrading RouterOS to the latest version. You can also try Wireguard instead of OpenVPN. You need RouterOS 7 for this.
I have updated my mikrotik to the latest version, but it still does not connect.
Does LM have integrated Wireguard as well?
Yes, check latest fw from forum.
Will the Firmware Released for imx28 devices ? In my case lm2i
Hey folks,
Since the latest update, Remote Service requests no longer work if the username:password combo is written in the URL. In this case, requests are being redirected (302) to the /login endpoint. This seems to have been a result of the new, cookie-based authentication introduced in the latest release.
Could you please help me get remote services working again with the username:password in the URL? Including an "Authorization: Basic" header solves this, but it will be difficult for me to update all existing code to include a header with the request.
Thank you.
@Sral1987, it will be published later this month
@manospsyx, basic auth still works but you have to explicitly send the header. We'll see if something can be implemented just for the Remote services but I cannot promise anything at the moment.
