Script reboot failing
I'm trying to reboot a wiser for KNX with a script.
Using this "os.execute('reboot')", the server doesn't reboot.
I also tested this "os.execute(reboot)" but i have the same result.
Respectfully,
BRUN Félix.
In General configuration there is Block unsafe functions in scripts:
Make sure to disable it.
(10.06.2024, 10:05)Daniel Wrote: In General configuration there is Block unsafe functions in scripts:
Thanks Daniel !
I have the same problem as fbrun@domizy to reboot LM5, I don't understand Daniel's answer
Jean-Marc
Utilities-> General configuration...
Thanks Daniel, it's OK
Is it also possible to reset the USB port by script, I have a Uart rs232 which from time to time blocks and I am obliged to unplug and replug
Jean-Marc
What is the device you have problem with?
It's : FTDI - FT232R USB UART
Jean-Marc
Did you check if just reboot helps? I think it will need power down anyway.
Yes reboot helps, I read the frame of a Linky electric meter every minute, some day at 8:00 a.m. the meter sends the tariff change and the ft232 blocks so either reboot or disconnect reconnect
It's not from the script!!
Jean-Marc
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869
-- Script USB Reset Final pour LM5 OpenRB -- Version simplifiée et optimisée local function write_file_safe(file, value)     local f = io.open(file, "w")     if f then         local success, err = pcall(function()             f:write(value)             f:close()         end)         if success then             log("✓ Reset: " .. file)             return true         end     end     return false end -- Configuration LM5 validée local USB_BUSES = {     "/sys/devices/platform/soc/2100000.aips-bus/2184000.usb/ci_hdrc.0/usb1",     "/sys/devices/platform/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb2" } -- Reset USB rapide et efficace local function restart_usb_lm5()     log("=== Redémarrage USB LM5 ===")         for i, bus_path in ipairs(USB_BUSES) do         log("Reset bus USB" .. i .. "...")                 -- Désauthoriser le bus         write_file_safe(bus_path .. "/authorized", "0")         os.execute("sleep 1")                 -- Réauthoriser le bus          write_file_safe(bus_path .. "/authorized", "1")         os.execute("sleep 1")     end         log("✓ Reset USB terminé")         -- Attendre la détection des périphériques     os.execute("sleep 2")         -- Vérification     log("Vérification des périphériques USB...")     local handle = io.popen("dmesg | grep -E 'ttyUSB|ftdi_sio|SerialNumber' | tail -5 2>/dev/null")     if handle then         for line in handle:lines() do             log("  > " .. line)         end         handle:close()     end         log("=== Fin du redémarrage ===") end -- Fonction principale simplifiée local function main(arg)     if #arg == 0 or arg[1] == "restart" then         restart_usb_lm5()     else         log("Usage: main({\"restart\"}) ou main({})")     end end -- Auto-exécution main({})
It's OK With the help of Claude.ai  Wink
Jean-Marc
You can power cycle USB port like this:
io.writefile('/dev/usbctrl', 'low') os.sleep(1) io.writefile('/dev/usbctrl', 'high') os.sleep(1)
Make sure that serial port is not open in a script when doing the power cycle. Otherwise the port name might change and script won't work.
