HardWare
Hello sir one of the client has taken us from LM5 Lp2  and he installed the streaming player firmware in it .
after that it is  stopped working  I tried to hardware reset it but it does not work .
sir could you pls provide dome suggestion and help
Follow this guide: https://kb.logicmachine.net/misc/reflash...ng-player/
hello sir I  tried it but it is showing this error
Try a different microSD card.
(18.06.2024, 12:11)admin Wrote: Try a different microSD card.
okay sir
Sir its Showing the same error in different new sd card
Then try a different SD card reader or use a different PC.
Thank you sir it is working now  Smile
hello sir i am resetting lm ambient and using new sd card it is showing this error
Are you using SD to micro SD adapter? If so you need to flip the switch on the side to disable write protection.
okk sir
