Need to create ripple effect with DALI RGB stripes
I use LM5 but have no experience with scripting.
I need to create a ripple effect on 19 zones of DALI RGB light tubes, with repeating waves with different tones of blue.
Can someone help me with this? Being paid.
Thanks and regards
Resident script with 0 sleep time. Script assumes that your RGB objects are addressed from 1/1/1 to 1/1/19.
colors table contains RGB color values in hexadecimal form. You can add extra elements if needed.
os.sleep(1) controls the time between each step (1 second in this example).
colors = {
  0xFFFFFF,
  0x7F7FFF,
  0x3F3FFF,
  0x0000FF,
count = 19
for i = 1, count do
  for j, color in ipairs(colors) do
    index = i + 1 - j
    if index < 1 then
      index = index + count
    grp.write('1/1/' .. index, color)
  os.sleep(1)
Thank you very much. Will try it.
Best regards
How can I create a script / routine to start a scene every 2 minutes. I have a scene that takes 2 minutes to execute. Then I wanted to start it again.
Is it possible?
Thank you
Run a scheduled script
