27.08.2024, 10:47
I have been asked to make some elements of the visualization "read-only" if a specified KNX object is off. Is there a way I can do this?
Change attribute in visu following a knx object
27.08.2024, 10:47
27.08.2024, 10:51
27.08.2024, 11:08
Okay, I saw the example. I am trying to make it work, but I need to know if it is possible to use more than one "additional class" per object since I already have a generic class handling the animations of all the buttons, and I need this to happen to just a bunch of those.
27.08.2024, 11:09
You can set any number of additional classes, separated by space.
27.08.2024, 11:31
Does not seem to be working, I probably got something wrong
I pasted this in in my javascript custom: Code: $(function() { pasted this in Custom CSS: Code: .el-disabled { and I used dis_da_totale as an additional class for the button is that correct, or am I missing something?
27.08.2024, 11:59
Your example works fine for me. Use browser dev tools (F12) to check if the element has a specific class.
27.08.2024, 14:10
Maybe then I did not understand what i supposed to do. Like I expected the button to stop working as long as the value of "32/1/22" is false. Is this correct?
27.08.2024, 14:11
(27.08.2024, 11:59)admin Wrote: Your example works fine for me. Use browser dev tools (F12) to check if the element has a specific class. I think he did not also add the class el-disabled to the additonal classes so the CSS does not apply to the element because of the class dis_da_totale is used, so intthis case the additional class needs to hold both dis_da_totale el-disabled or am i wrong?
27.08.2024, 14:14
(This post was last modified: 27.08.2024, 14:17 by Andrea Becagli.)
(27.08.2024, 14:11)Erwin van der Zwart Wrote:(27.08.2024, 11:59)admin Wrote: Your example works fine for me. Use browser dev tools (F12) to check if the element has a specific class. I just tried that but it makes the element disabled no matter what the value is. I forgot to say that I checked with dev tools and the element seems to have the "dis_da_totale" class
27.08.2024, 14:24
Post a screenshot of the relevant visualization element settings.
27.08.2024, 14:36
(27.08.2024, 14:24)admin Wrote: Post a screenshot of the relevant visualization element settings. I have attached two screenshots: the settings and the actual visu. "uso TOTALE OFF" is the object which should lock the buttons below
28.08.2024, 13:58
Send your backup via PM. Use WeTransfer or another similar service.
28.08.2024, 18:00
(28.08.2024, 13:58)admin Wrote: Send your backup via PM. Use WeTransfer or another similar service. Here you go: https://we.tl/...
29.08.2024, 15:49
It's not working because the previous function in Custom JavaScript fails with an error. Change it to this and it will work:
Code: $(function(){
29.08.2024, 16:15
(29.08.2024, 15:49)admin Wrote: It's not working because the previous function in Custom JavaScript fails with an error. Change it to this and it will work: Thanks, admin. Problem solved as always ![]() |
